09-11-2009, 11:54 PM | #1 |
Brake line routing
Can someone send me some pictures of how they have their brake lines routed from their master cylinder to the first splice? I'm going to attempt to run new brake lines this weeknd (with the motor/trans out) and I want to make sure I give myself enough clearence. I no longer have the original brake lines and I didn't take any pictures (GRRRR).
09-12-2009, 12:01 AM | #2 |
Senior Enthusiast
Re: Brake line routing
What year is your truck, and are you running stock brakes or a power booster and dual master cylinder?
09-12-2009, 12:07 AM | #3 |
My truck is a 65SWB. I'm running a factory power drum booster from a 64 C-20.
09-12-2009, 01:48 AM | #4 | |
Senior Enthusiast
On the proportioning valve question, most people use something close to a factory setup next to the booster which I don't like. It looks cluttered and makes it difficult to reach the sparkplugs. The 2nd two pics show how I routed mine. I bolted the proportioning valve to the back of the crossmember, behind the motor mount tower - so you should be able to mount it anywhere convenient. Rather than relying on coils in the line(s), I use multiple bends (6 to 8 per line) instead. This gives the tube plenty of flex so there are no stress problems, and in my opinion look much neater than coils. |
09-14-2009, 11:12 PM | #5 |
Thank you Markeb01 for the idea on the PV location. Here's what mine looks like. The lines are just for template. The second picture is the bracket I made from scrap metal. The whole thing can be removed if needed. The PV is level with floor.
09-12-2009, 12:08 AM | #6 |
Great question, I also have the engine out and need to figure it out. I got a proportioning valve from an 86 truck with the brake lines back to the master cylinder. I was wondering if I could put it under the radiator? I started today and ran into the same problem.
09-14-2009, 11:28 PM | #7 |
Senior Enthusiast
Good for you. I like these out of the way locations much better than cluttering up the booster area. You may already do this, but I use wire coat hangers to make tubing patterns, then do all my tube bending on the bench. Having a full scale layout really helps not make the bends go the wrong direction.
And of course, when doing the flares always make sure the fitting is on first! |
09-15-2009, 12:21 AM | #8 |
Yeah no kidding on the fitting first. That's so funny when you find out you make a perfect flare then realize opps. I did that right off the get go. Thank you again.
