09-12-2009, 07:28 PM | #1 |
Converting Lower Radiator Mount for V8
My 63 C20 had an I6, and therefore the lower mount as shown in the pic. Should I move the crossmember fwd and moVe the lower mount pads to the lower holes, or can I use the stock I6 location and just use an aluminum radiator for my 350?
09-13-2009, 12:42 AM | #2 |
60-66 Nut
Re: Converting Lower Radiator Mount for V8
No need to move the crossmember. What is shown in the pic is the location of the mounts for a V8 radiator. I'm not sure why yours is that way when it had a I6. Typically the I6 radiators had the lower mounts on the lower portion of that crossmember. How does your radiator look like? Is it a 2 row or a 3 row? A good 3 row radiator with a shroud should have no problem cooling your 350. Of course the aluminum radiators you mentioned will work good also.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-13-2009 at 12:45 AM. |
09-13-2009, 01:14 AM | #3 |
From my searches . . ....
Small I6 = lower mounting on the c.member & small brackets Big I6/V8 = upper mounting on the c.member & larger brackets
09-13-2009, 09:03 AM | #4 |
It is a C20 and it may have had the larger I6 292, I never did check the numbers. It just seemed like if the mounts were lower you could put a taller(larger) radiator in it, but perhaps with it above the frame rails, you can put in a wider one. I am going to try and find an aluminum one as I will be towing with it and want the best cooing possible. Thanks for the info guys!
09-13-2009, 11:56 AM | #5 | |
http://67-72chevytrucks.com/vboard/s...minum+radiator
09-13-2009, 02:10 PM | #6 |
Nice link, that looks like the plan, I can probably do something along those lines, in fact my truck will look very similar to his, except for the stance. Thanks again guys!
09-13-2009, 11:22 AM | #7 |
the v-8 radiators were/are wider.
CHEVY ONLY Last edited by joe231; 09-13-2009 at 11:22 AM. |
09-14-2009, 10:33 AM | #8 |
Photo of V8 stock upper radiator mount...
