Hollister Road Co.
55-59 Firewall Replacement
I just finished replacing a firewall on a 56 and thought I would share the info. The idea was to clean up the firewall and smooth out the upper section. The owner wanted to get a premade firewall that was recessed but cost was a big factor in they way we did this one. As you can see the original was very damaged from a clutch explosion and far beyond repairing. We priced a firewall and floor section at about $675 plus about $150 in shipping. We also priced a sheet of 16 gage 4'X8' @ $38.00. We went with the 4x8 sheet.
The pictures that follow are fairly self explanitory but I'll fill in where I think some detail is needed. We made a cardboard template that fit the way we wanted the completed firewall to look. Using a hot glue gun to attach the various pieces and firm up the model made it much easier. |
Hollister Road Co.
Re: 55-59 Firewall Replacement
With the model done we removed it and cut it apart where we wanted the folds and cuts to be. The technique we used to do the bends on 16 ga without a brake was making cuts along the bend lines with a plasma torch. The .030 slits were easily welded up when we were at that point. At each bend point we made a cut 1" long a 1/4" from the end and followed that pattern of 1" 1/4" all the way to the end of the bend.
Hollister Road Co.
We bent the panel into place by hand and proceeded to the next panel.
nice work, you have to love plasma cutters.
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
Hollister Road Co.
We cut out and tacked in place the other pieces just like a puzzle.
Hollister Road Co.
Next we bent the toe boards into place.
Hollister Road Co.
We trimmed out the original toe boards filled in the toe area. All thats left it to mate up the toe to the original floor.
Hollister Road Co.
We didn't cut out the lip that goes around the firewall we will use a 2" strip of the original firewall we left in plce to weld the new firewall to. We left enough all the way around to put plenty of rosette welds and not have to disturb the original spots welds. We end up with a very flat smooth firewall.
Nice job on the firewall! But I have to ask, how did the old firewall get so banged up?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#10 | |
Hollister Road Co.
From what I was told the clutch exploded during a drag race. I have only heard about flywheels coming through the bell housing and the damage it can cause but never seen the actual results until now. I'm sure there was an equally large brown spot under the driver seat when it happened. |
A320 Pilot/USAF Retired
Looks awesome!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#12 | |
Hollister Road Co.
Maybe the NHRA had the right idea on bell housings.
I don't remember who but a famous Top Fuel driver lost part of a foot like that back when the engines were in the front of the driver. |
Don Garlits, first to run rear end AA/F because of it.
#15 |
You might want to double check that Garlits was the 1st. the Kaiser Bros., Bernie Schacker, Duane Ong, Duane Ong won an AHRA event with a Woody Gilmore car before Garlits built his. No doubt of the clutch explosion and the damage done
dwcsr - Firewall looks great. |
#16 |
'56 Big window 350/700r4 9" rear w/disc |
#17 | |
Hollister Road Co.
Once the cab is bolted down you can replace just about anything and be sure it hasn't sprung out of place. |
