Old 09-14-2009, 03:40 PM   #1
quadracer812
quadracer812's Avatar
will an 84 3/4 ton front crossmember and suspension fit?
he is the thing. I got an 84 3/4 ton truck sitting here. havn't looked drastically at the differance in the frames but would the front suspension crossmember work on a 65 half to? its here and free and don't mind the 8 lug cause I got some nice wheels to go with it., if not i'll just get a 1/2 ton for the disc
quadracer812 is offline   Reply With Quote
Old 09-14-2009, 10:14 PM   #2
Eagar1
Re: will an 84 3/4 ton front crossmember and suspension fit?
The front crossmember will bolt right in, but you will need to get an adapter plate from CaptainFab for the gearbox. The rear end may have to have the spring perches changed out to use the trailing arm/coils.
There isn't any reason why you can't make it all work especially with a complete donor vehicle.
Eagar1 is offline   Reply With Quote
Old 09-14-2009, 11:06 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
you could always just use the leafs and hangers off the 3/4 for the rear..
Old 09-14-2009, 11:50 PM   #4
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
What are your plans for the truck? Bagged? if so you may want to just use the whole frame. Then you dont have to Z the front to get it to lay out. Just throwing that out there if you were wanting to bag it.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-15-2009, 03:29 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Justin, check this info out. I posted your question in the 73-87 board and got you some answers. Hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=362632
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
