09-15-2009, 01:04 PM | #1 |
Aftermarket dog dish center caps
Can someone confirm that the stock steel wheel size is 15X6.5 or somewhere around there. I have been looking for a set and found some.. but this was the measurement. I was hoping to find 15X7 or X8. I do believe these will work though.
Also does someone know where I can purchase aftermarket dog dish caps for my 69 c/10. |
09-15-2009, 01:07 PM | #2 |
Old Skool Club
Re: Aftermarket dog dish center caps
How did you measure the wheel width? You should be measuring inside the lip, from side to side. I believe the stock size original wheel was 15x5.5, but if you measure across the outside lip-to-lip it will be close to 6.5 inches wide.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-15-2009, 02:21 PM | #3 |
SWB 4x4 Collector
They make 15 x 8 steel wheels, but they hard as hen's teeth to find. I finally found a set of them for $75, so I gladly handed over the cash. The original wheels were 15 x 6". Also, there is no place that reproduces the dog dish hubcaps, you will have to find a set used or nos. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
09-15-2009, 09:23 PM | #4 |
Yeah, this is what I concluded to a year ago when I started looking. Kind of makes you wonder why though. Then again, now guys are wanting to go back original.
I have not purchased the wheels yet (better for another set gets away) but the seller says he measured from outside to outside edge. He said it was more like 6 5/8" to be exact. I do not know what stock was so was sort of asking that as well. They do make a 15X8 6 lug (I let a set get away) but was wondering what the stock size was. Do these look to small on a good sized tire. Was asing because I can get them or hold out and look for a 15x8 set. Of course the wider one might be better. |
09-15-2009, 09:45 PM | #5 |
SWB 4x4 Collector
the 8" wide are good up to a 12.50 width. The 6" wide wheels were the stock size width wheels for these years, and I believe would be fine to a 9.50 width tire. I wanted to find the 8"s for my 35-37" 12.50 width off road tires. Trevor
