I am going to start putting the pieces back together so that I can prep them for primer and know that they are going to line up when I go to install them. I was going to start with placing the cab on the frame then installing the front clip. The main reason I am doing this is to check the body lines My question is should I assemble the box and put it on too? Or take the chance for some fluke reason once everything is painted it wont line up right (that would require getting a LWB floor and cutting it to size cuz I cant find a shorty anywhere!) I think the answer is getting more clear as I keep typing. The reason I am doing this is that all the body pannels have never been installed on this cab before. Any advice would be great on how to put everything back together!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I want to know how you guys would do it .
Almost Satisfied
![]() Join Date: Mar 2002
At this point I don't plan to worry about the bed. I want to align the fenders, hood, doors, etc. but I figure the bed is somewhat independent and can be adjusted later. Mine is a step so I think it is a little easier than the fleets to get lined up.
To have a piece of mind I would put your bed on and line it up. That way you aren't second guessing yourself. I see in your sig that you shortened your frame so it may be a good idea to ensure everything lines up.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Cool thanks foryour reply Just trying to get the process sorted out . Going to put the cab on the frame tonight.
in WAY over my head
I will be doing similar..
my 67 front clip has never graced itself with my 71 cab.. infact.. my 71 cab has never graced itself wiht my 69 frame.. my 67 bedisides not a steel floor seen.. and theres still no tailgate heh I look at the body as 1 peice.. what I plan to do is have the body panels painted before they're put oin the truck.. then we assemble them.. get it roughed in.. and take it back to the body shop for a panel alignment with a micrometer.. it might take more that way but.. thats what I'm thinking at this point. btw the avatar represents my latest addition so you can see where I am at this point.. a few misc. parts shy of an engine-less rolling chassis.. so I have a whlie yet let us know how it turns out |
UK Wildcat Fan!
is it safe to assume your doors are on the cab and lined up? that's the first step then install cab. If you're sure the cab supports were good and you didn't have to worry about the cab sagging if/when you welded replacement cab panels in there shouldn't be any problem w/ the cant of the cab being off (as compared to the frame). throw the hood on (not bolted on-just to ensure a less likened chance of scratching the fenders during install-unless you're lucky enough to have help :-) and work your way around w/ the fenders. The grill is a stationary object so your distance between them will have to be set, but that also matches up with the width of the hood. Worse case is shimming out the fenders to meet the door and cowl.
in WAY over my head
is it a bad idea to not test fit these items on the frame before painting?
as far as I know my personal cab isn't sagging, but I havenb't really looked yet.. body work was going ot be a chore all its own.. now that you're talking about this. its got me thinking heh |
