Old 09-16-2009, 07:14 PM   #1
brak
brak's Avatar
creating a trailer from longbed frame and bed
I've got the long frame and bed from my truck swap, and i can't bring myself to cut it up for scrap, so i decided i'll make a trailer to haul behind my now-shortbed '72... (i think it'd look, cool color coordinated)
My question is, has anybody done a writeup on this?
I've searched, but haven't found anything
I'm most interested in the best way to bring the frame together to form the tongue.
I figured i'd notch the upper and lower lip of the frame, and bend them together, to maintain structural integrity, but i'm curious about the best way to get them to bend.
any suggestions?
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 09-16-2009, 07:18 PM   #2
vtblazer
vtblazer's Avatar
Re: creating a trailer from longbed frame and bed
Remeber reading somewhere on here that someone was saying leaf spring suspension was bad for pickup box trailers and coils were the way to go.
vtblazer is offline   Reply With Quote
Old 09-16-2009, 07:44 PM   #3
michael bustamante
michael bustamante's Avatar
Ive got the exact same set up ready to convert to a trailer so Ill be following this!!
1967custom
michael bustamante is offline   Reply With Quote
Old 09-16-2009, 08:14 PM   #4
brak
brak's Avatar
yeah, the truck was 2 wheel, so it has coils.
i had contemplated picking up a trailer suspension from northern tool, but it wouldn't be worth the cost and effort. i figure the coils will give it a nice ride, and i'll just pick up another set of trailing arms for my project truck...
Old 09-16-2009, 09:18 PM   #5
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
There are a lotta ways to do this but here are some pics of a 54 trailer
powerdriver 1958 is offline   Reply With Quote
Old 09-21-2009, 05:50 AM   #6
brak
brak's Avatar
Thanks to the pics powerdriver 1958 posted, I got it figured out....
Here's what i accomplished yesterday:
I cut the frame rails directly behind the front cab supports, and they ended up being the perfect length, quite by accident...
I measured 8 inches forward from the bed mounting pads, in order to avoid having to mess with the rear cab mounts (i'm so sick of rivets, but that's another story).
i cut 45 degree angles under the assumption that i would create an equilateral triangle because the frame is 34" measuring across to the outer edges of the frame, and from where i initially cut, i had almost exactly 34", but i suck at math, and didn't account for the 3" wide tube, and a couple other factors, but all in all, here it is
i still need to strengthen the gaps where i screwed up the angles, brace the center piece, and pick up a coupler.
on a side note, once i notched the upper and lower edge, the frame rail bent with little force, which was my biggest concern starting out
i'll post more pics later
Old 09-21-2009, 03:53 PM   #7
michael bustamante
looking good. it looks like you and I have the same length frame to work with. thanks for the heads up on how much angle to cut out.
I still have to remove the tranny crossmember but other than that Ill be following your instructions!
1967custom
Old 09-21-2009, 04:10 PM   #8
brak
brak's Avatar
unless you want to go shorter, 45's are not the way to go
I REPEAT... Say NO to 45's
yeah, i think the 8' box will make a great trailer
