09-17-2009, 05:13 PM | #1 |
"Trucks with Class"
Home Made HEI Tester...
After a day balancing on the radiator of my 79 dually with my feet/legs stuck straight up in the air, I decided I had to have a tester for HEIs. That's just too hard to do in the truck. Changed the module-nope...changed the rotor-nope...cap & coil-nope...complete HEI-yup!
Here's my answer to bench testing. Pics should tell the story. Last edited by PICKMUP; 09-17-2009 at 05:17 PM. |
09-17-2009, 05:15 PM | #2 |
"Trucks with Class"
Re: Home Made HEI Tester...
and...fire in the hole
09-17-2009, 05:53 PM | #3 |
sharp as a marble
That must be on of those new fancy POD ( power on demand ) kind of distributors. I see 8 spark plugs, and 8 plug wires, but only 6 little blue flames. DUDE what is up with that haha
09-17-2009, 07:12 PM | #4 |
"Trucks with Class"
The other two are just hidden behind the dist and don't show in the pic. Hittin on all 8 now!
09-17-2009, 10:47 PM | #5 |
Sweet setup!
09-17-2009, 10:52 PM | #6 |
The Older Generation
OK, nobody ever accused me of being too smart... What turns the shaft? LockDoc
09-17-2009, 11:30 PM | #7 |
Eat My Rust
If the dizzy is being spun fast enough, it's possible that all 8 plugs fired while the shutter of the camera was taking the photo, especially the dark picture
09-18-2009, 08:28 AM | #8 |
Back in the sticks
I don't care what you say, thats just cool
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
09-18-2009, 10:28 AM | #9 |
My guess would be hes using a drill and an oil pump rod to spin it. Reason I guess that is cause thats what I use for mine that I made in shop class in high school. Handy thing to have around. When you have a dist thats questionable. Yours looks way better than mine though!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
09-18-2009, 12:08 PM | #10 |
Active Member
Wow! Some would say "overkill" just to test a distributor since most of us just pull the plug wires and ground them... but I say inginuity.
09-18-2009, 12:11 PM | #11 |
Active Member
Forgot to add... I bet some auto mechanic shop teacher would love to have it or borrow it as a teaching tool.
09-18-2009, 12:17 PM | #12 |
"Trucks with Class"
You are all basically right...spin it by hand or drill, slow shutter made them all "show" in the pic, I used to just pull a plug wire & ground it, but too much "air time" dangling over the motor cured me.
I can now test all used ones before I install or sell them. |
