![]() Join Date: Aug 2007
Measurement Help
I thought I saw these on here before but I could not find them when searching.
I am getting ready to cut into the floor and rockers and I need some measurements before I start to brace everything. I appreciate any help. Need A,B and C measurements and anything else you think would be helpful. ![]() |
Junior Member
Re: Measurement Help
Here is a link to the thread with those measurements.
http://67-72chevytrucks.com/vboard/s...g+measurements
1970 blazer, street/strip project 1963 ford fairlane sports coupe 50,000 original miles |
USMC
can you put the top on? It might be easier then you can put the doors on (and off a bunch of times....)while your working on it to check the lines.
Semper Fi |
#4 | |
Read the thread...just don't look at the pic, the bottom door measurement is in-correct in the posted picture. Last edited by vtblazer; 09-20-2009 at 06:31 AM. |
#5 | |
Make sure your body mounts are in great shape prior to any re-insallation of metal, if they're not replace them with new. Here's some measurements I took last week for another board member from my untouched 69. Your 'A' measurement: ![]() ![]() Your 'B' measurement: ![]() ![]() Your 'C' measurement: ![]() ![]() Here's a couple so you can check your winshield frame angle too: * Note where the plumb-bob string is hanging from, so your accurate when trying to match the numbers. ![]() ![]() ![]() Last edited by vtblazer; 09-20-2009 at 06:32 AM. |
Can't wait to retire!!
Hey Kurt, are you sure you're not a plumber? I saw the Kohler box and the plumb-bob?
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Good Stuff!!
I'm printing these off for the shop now. The only caution I'd make is that the "plumb bob" measurement will only be valid if the tub is 100% level to the ground. Otherwise I'm sure it could easily be off by 1/4" or more in either direction.
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
#9 | |
Really good point to remember, pic shows the blazer floor orientation when those where taken. |
Awesome, that is excatly what I needed. Thanks!
