Old 09-21-2009, 05:31 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Push rod length
Ok... so am I stupid or what??? (don't answer that)
I gots me a set of 23* Trick Flow Cylinder Heads, for my 350 (now355), and they say that with a hydraulic flat tappet cam, and roller rockers, I should be needing a 7.85" push rod.
But when I pull out my trusty push rod measuring thingy, I get 7.6"...
What the crap yo?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 09-21-2009, 05:55 PM   #2
cdowns
cdowns's Avatar
Re: Push rod length
sounds like you need to buy a set of pushrods that are 7.85 in lenngth to use the headss . common enough in custom building that you need to buy new stuff
Old 09-21-2009, 05:57 PM   #3
toddtheodd
toddtheodd's Avatar
Re: Push rod length
No no... I'm saying that the push rod measuring thingy says I need 7.6"
At 7.85, I was almost coming off the outside edge of the valve tip when it opened the valve.
7.6" kept me centered (as best as can be for something moving back and forth) from close to open.
IIOY???
Old 09-21-2009, 05:56 PM   #4
toddtheodd
toddtheodd's Avatar
Re: Push rod length
I guess I should also ask... have y'all built a fresh motor, and when you measured the push rods (10 times) needed, they were WAY OFF of what was recommended?
IIOY???
Old 09-21-2009, 06:22 PM   #5
mclairmo
Re: Push rod length
I would go with 7.6.
mclairmo is offline   Reply With Quote
Old 09-21-2009, 06:30 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Re: Push rod length
Is your block decked?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-21-2009, 08:24 PM   #7
toddtheodd
toddtheodd's Avatar
Re: Push rod length
I don't think so...
I'm using the 23 Trick Flow heads, Comp Cams Extreme Energy 274 hydraulic flat tappet cam, and Crane 1.5 Energizer roller rockers.
The heads are the only thing that says anything about push rod length... the cam and roller rockers say nothing...
edit:
Oh... and I measured it with the heads already on the motor, and torqued down... so this is the actual length, and not the length plus compressed head gasket thickness and whatall... it is already compressed.
IIOY???
Old 09-21-2009, 08:43 PM   #8
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Push rod length
Originally Posted by toddtheodd View Post
I don't think so...
edit:
But sinister is right. If your block was decked it would affect push rod length. One way to check is look at the stamp on the passenger side of the block (in front). If the numbers are missing you had some deck work done.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-21-2009, 08:50 PM   #9
toddtheodd
toddtheodd's Avatar
Re: Push rod length
s/t
Nope... numbers still there. I noticed them when the motor came back from the machine shop, because I never saw them before under the 14 inches of oil and sludge that was on the motor.
IIOY???
