Old 09-22-2009, 07:28 PM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Speedometer gears for a 4 speed SM465?
I have a 71 C20 that has the 4 speed tranny. I think they call it a SM465?
My speedometer is reading about 8-10 miles per hour too fast.
Anyone know what kind of speedometer gears these take. Are they the same ones used in a turbo 350? Or a special kind and if so, where to buy?
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-24-2009, 10:08 AM   #2
bobs409
bobs409's Avatar
Re: Speedometer gears for a 4 speed SM465?
bump
Bob
Old 09-24-2009, 10:18 AM   #3
airdale94
airdale94's Avatar
Sorry don't know the answer. I can't imagine why it would be off unless you made some considerable tire/rear end changes. This came up on Google. My NP435 has one. But the 2 SM465's I have do not.
http://cgi.ebay.com/ebaymotors/SM465...=p4506.c0.m245
airdale94 is offline   Reply With Quote
Old 09-24-2009, 10:43 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
My NP435 has that same type of gearbox between the case and the speedo cable. It says "666F and on next pad it says 1.1111 and it seems to INCREASE the speedo reading by that amount (.1) ie. 50MPH without it, 55MPH with it attached. So if you get one of these make sure that the value is correct for your needs. Someone else will know more I'm sure.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-24-2009, 02:57 PM   #5
airdale94
airdale94's Avatar
I also found this.
http://www.bethsbackyard.com/NP540GL...escription.htm
Evidently you buy different ratio reducers.
Scroll down to the speedometer section.
Old 09-24-2009, 06:54 PM   #6
bobs409
bobs409's Avatar
Thanks guys. I'll look into one of those.
Bob
Bob
Old 09-24-2009, 07:02 PM   #7
john
member #16
john's Avatar
Bob my speedo was 15 mph off at 60 mph. I had my local speedometer shop make an adapter as pictured and it is reads correct now according to the mile markers.
john is offline   Reply With Quote
Old 09-24-2009, 07:42 PM   #8
Tynee
I miss this truck.
Tynee's Avatar
I believe that the speedo gears are available through the dealer for a decent price. I did a little reading on this a while back on a chevelle forum, I've lost the link since then. If I remember correctly, there is a process by which you can determine how much higher or lower, numerically speaking, the new gear needs to be. This will reduce the amount of trial and error involved in getting the right gear in there.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 09-24-2009, 10:01 PM   #9
BCOWANWHEELS
call atlanta gear and axle. they have different speedo gears for your sm465
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
