09-24-2009, 09:50 PM | #1 |
Just here to tinker
3-Speed question
I got a question concerning the early 3-speed transmissions and their bolt patterns.
The bell housing on my '60 has provisions for 5 bolt holes but the tranny (SM-318) only has 4 bolts. Now, I've seen 3-speeds with five bolt holes. The question is what trucks did the 5 bolt pattern tranny's come in and what trucks did the 4 bolt pattern come in? I'll try and find some pics....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-24-2009, 10:00 PM | #2 |
Just here to tinker
Re: 3-Speed question
here is my tranny with the 4 bolt hole pattern like most that I have seen
And I take that back, I don't have the 5 bolt bellhousing:
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 Last edited by Corts60; 09-24-2009 at 10:02 PM. |
09-25-2009, 09:13 PM | #3 |
Just here to tinker
Anyone? Bueller?
09-26-2009, 01:01 AM | #4 |
Senior Enthusiast
I'm assuming you mean the mounting holes. Does the 5 hole transmission have 5 mounting ears? I'm curious where the 5th holes is located.
Most 3 speeds I've seen look like the one you pictured, except perhaps with a shorter or longer tailshaft. The only exception was pre-55 trans with a torque tube which had a smaller and narrower pattern. Do you know for sure if the 5 hole transmissions were a GM product? |
09-26-2009, 11:33 AM | #5 | |
Just here to tinker
09-26-2009, 11:52 AM | #6 |
Just here to tinker
Here's the pictures:
Maybe these came in the big trucks?
09-26-2009, 11:14 PM | #7 |
Senior Enthusiast
Wow that looks like the biggest 3 speed ever. The gearset must be huge. The side cover looks twice as big as anything I've seen. I think you're probably right about it coming from a big truck. It seems older with what appears to be a 10 spline pilot shaft. Of course when's the last time anybody made a 3 speed manual.
I'm curious now and going to do some more research. If you figure out what this is please post the results. |
09-26-2009, 11:19 PM | #8 |
Senior Enthusiast
Looks like it is a heavy duty GM Saginaw transmission per the following weblink:
http://columbus.craigslist.org/bar/1384236089.html |
09-27-2009, 12:12 AM | #9 |
Just here to tinker
Well, that's awesome! Thanks Mark.
Now I wonder what bellhousing goes with it?
09-27-2009, 12:39 AM | #10 |
Resistance is Futile
Do you think it would fit on your bellhousing and just skip the upper bolt?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
09-27-2009, 10:39 AM | #11 |
Just here to tinker
It would probably bolt up, but I think they have that extra ear for the weight since there is no tranny mount on my year of truck. So it has to be an early style tranny when engines still had "rear engine" mounts instead of tranny mounts.
09-28-2009, 10:17 AM | #12 |
I use a heavy duty, all-synchro Muncie 3-speed in my 64 C10. It is just as large/heavy as the transmission in lower photograph, and it works just fine with that type of bellhousing and no rear mount. I have never seen a transmission with that 5th mounting hole up top though.
09-28-2009, 02:18 PM | #13 |
Senior Enthusiast
Come to think of it, my 1960 GMC had the granny 4 speed installed when I bought it, and it only had the standard 4 ear bolt pattern with no tail mount. It seemed that thing weighed as much as a small car engine, so I would imagine it would be okay to ignore the upper bolt on the heavy duty 3 speed.
It would be interesting to come up with a 5 hole bellhousing however, just to confirm one can be found. |
