Old 09-25-2009, 12:27 AM   #1
Storm Chaser
Storm Chaser's Avatar
hydroboost...
I have the hydroboost setup left over from my abandoned 88-98 project. Can it be used on my 88 R20? What do I have to do to get it mated up to the firewall?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-27-2009, 03:24 AM   #2
Storm Chaser
Re: hydroboost...
Anyone?
1988 R2500 Crew Cab
Future plans-
Old 09-29-2009, 10:34 PM   #3
Storm Chaser
Re: hydroboost...
OK, let's try it this way... is the hydroboost unit the same between the two bodystyles, not counting the bracket? In other words, could I remove the 88-98 bracket and find/fab one from a pre-88? Surely someone's messed with hydroboost.
Has there been a mass exodus away from the 73-87 portion of this site? Seems alot of old regulars are pretty quiet...
1988 R2500 Crew Cab
Future plans-
Old 09-29-2009, 10:40 PM   #4
Number21
Number21's Avatar
Re: hydroboost...
Hmmm...I could probably take a pic tomarrow of the hydroboost in my '79 if that would help. Otherwise I don't know much about the system...
Number21 is offline   Reply With Quote
Old 09-29-2009, 11:55 PM   #5
Storm Chaser
Re: hydroboost...
That would help me out a bit, if you don't mind. Thanks!
1988 R2500 Crew Cab
Future plans-
Old 09-30-2009, 09:22 AM   #6
Cherub
Cherub's Avatar
Re: hydroboost...
1 tons came with hydroboost. With a little fab you can adapt it.
Cherub is offline   Reply With Quote
Old 10-01-2009, 03:59 AM   #7
Number21
Number21's Avatar
Re: hydroboost...
Here's some pics of my Hydroboost. It seems to be mounted on some kind of bracket which is then attached to the firewall...
Old 10-01-2009, 07:10 PM   #8
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: hydroboost...
Not all 1 tons came with hydroboost, If it came with a small block it had the regular vacuum booster. All big block trucks came with hydroboost because they don't make enough vacuum.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-01-2009, 07:55 PM   #9
mbgmike
Re: hydroboost...
I don't know why you could not. They have put Hydro-boost systems in all kinds of cars and trucks. A buddy of mine has one in his 38 chevy car. Can you not use the bracket you have.
mbgmike is offline   Reply With Quote
Old 10-01-2009, 10:39 PM   #10
boatpuller
boatpuller's Avatar
Re: hydroboost...
sorry check below
boatpuller is offline   Reply With Quote
Old 10-01-2009, 10:41 PM   #11
boatpuller
boatpuller's Avatar
Re: hydroboost...
here's a couple of old ones i had on file.maybe you can see something ?
" Never look up a dead dogs butt."
Old 10-02-2009, 12:02 AM   #12
Storm Chaser
Re: hydroboost...
WOW, can I just have that entire engine compartment? As far as I can remember, the brackets posted in this thread seem to look like what I have.
Do you think (assuming the bolt patterns are the same) if I measured from the hole in the brake pedal to the firewall and add that to the distance between the firewall and the face of the hydroboost unit... if that summed distance is the same or pretty darned close to the same on my truck... it would be safe to assume the rod is the correct length?
1988 R2500 Crew Cab
Future plans-
