09-27-2009, 05:20 PM | #1 |
New truck finally, couple questions
I finally went and bought a '70 3/4 ton 4x4, It has a 383 with roughly 30000 miles on it since it was rebuilt, and a 350 tranny that seems to shift smoothly. Everything is pretty straight, but has rust on both front fenders, which I am going to buy new fenders to fix. I got it for $2500 which I thought was a decent deal. Runs pretty good. The owner drove it to Arkansas and back last year with out problem.
The problem: after you shut off the motor, it is hard to restart. I have to turn it over for a little while and pump the gas pedal and eventually it starts. Runs good after that. The carb is a new edlebrock. Any ideas? And the pics: |
09-27-2009, 05:29 PM | #2 |
Re: New truck finally, couple questions
Nice truck winch included. Can't help with your starting question though, sorry.
09-27-2009, 05:37 PM | #3 |
my truck was doing the same thing you say and i adjusted the timing a little bit and it fixed my problem
72 cheyenne super 83 chevy...4x4...454 |
09-27-2009, 05:57 PM | #4 |
Sweet truck! And a great price. Try the timing, sounds good to me.
72 k20 Cheyenne Super 350 Turbo 400 Dana 44 Front / 60 Rear NP 208. 315 70 17 Hummer H2 wheels. Black. |
09-27-2009, 07:11 PM | #5 |
That's kinda what I was thinking. Have any idea of what it should be timed at? I have gun to do it.
Thanks, Jesse |
10-04-2009, 12:51 AM | #6 |
Couple more questions:
I think the truck was advertised as a '71, but when I got home and actually looked at the pink, it is a '72. I am not familiar with any of the models. It has bdges that say custom 20 I believe. Is this right? Also, what axles and is there any way to tell what gear ratio it has? Thanks, Jesse |
10-08-2009, 11:27 PM | #7 | |
10-04-2009, 09:29 AM | #8 |
R.I.P. E.S.L.L.
Looks like a 72 to me judging by the door panels and mirror.
Custom 20 is a 3/4 ton truck so that is correct. Nice truck, that's a helluva front bumper.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
10-08-2009, 11:51 PM | #9 |
Do you have headers? Maybe your starter is over-heating. If it starts great cold and only hard to start after you have been driving, you may need to put a heat shield or wrap on the starter.
67 Stepside Atomic Orange Fastburn 385 TH350 The wheels are fronts are 255-45-18 with 5" bs. 18x8 wheel rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit) Budget: A method for going broke methodically. You only live once! |
10-09-2009, 12:21 AM | #10 |
Which carb do you have?
Sounds like to me like the bowl is bleeding off. Try running some lucas oil fuel system cleaner through it. Make sure you run Super Unleaded too. With that motor your timing should be around 10 degrees at 1000rpm idle with the vacum line off the distributor and plugged. Last edited by highperf4x4; 10-09-2009 at 12:22 AM. |
10-10-2009, 11:13 AM | #11 |
I decided to drop the truck off at a local shop and have them look at it. One of the bolt holes in the head for the headers were stripped out and I didn't want to tackle it. He fixed that, put in new header gaskets, adjusted the carb and timed it. Sounds and runs good now.
I am getting new wheels and tires later this week and also getting the bed Line-x'd. I'll make sure to take some pictures when its done. Another question, you can kinda see from the pictures that the front is lower than the rear, about 1 1/2 inches. The rear has about a 2 1/2 block for the lift. The front springs are flattened out with age and that heavy bumper and winch. How would I go about picking new springs to try and level the truck out? What company? Thanks again, Jesse |
10-10-2009, 11:24 AM | #12 |
You might try over in the 4WD section - those guys are pretty good with those kind of questions. All we try to do over here is lower 'em. Very nice truck, BTW.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
