Newbie 1964 GMC Build
Hello, I am glad to have found you guy's
![]() ![]() Picutre One - Truck when I first got it doors were in the backyard w/ all the other parts and I still needed to buy glass Picture Two - Old Engine looked okay until I tore into it Picture Three - sanded the body and Primered front and outside of the bed Picture Four - Truck with Glass Picture Five - Grille from Terd Fergeson... Thank you ![]() Last edited by Rusteeze64GB; 09-28-2009 at 04:07 PM. |
Re: Newbie 1964 GMC Build
First pic - Old Engine
Second pic - I6 250 Third pic - 2 Friends helping with removal of old Fourth pic - Empty bay I have done alot of cleaning after the engine was pulled. I also have painted the firewall black after sanding and cleaning. I also plan to do the wrinkle paint on the side panels in the engine bay The 250 has been cleaned and painted should go in by Tuesday October 6th. I will have more pictures later ![]() Last edited by Rusteeze64GB; 09-28-2009 at 04:08 PM. Reason: Wanted to add details. |
283 Drama Queen
![]() Join Date: Dec 2004
Welcome to the looney bin.
Nice start on your rig! Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
meowMEOWmeowMEOW
looks like a pretty clean truck to work with. Hell, for only $975 seems like you got a good deal even if the motor was stuck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Yeah that is what everyone that has seen the truck in person has told me. There is no rust in the cabin. The rockers, cabin corners, doors all rust free. There is alot of dirt under the truck that I have been working at slowly but rust is a 5 out of 10 on this truck. Got lucky there. I know it definalty helps knowing that this truck has been in Az for the last 10 to 15 years. Dry as hell if not drier.
![]() Last edited by Rusteeze64GB; 09-28-2009 at 04:40 PM. |
Senior Enthusiast
That's a great plan, and nice starting point. Set a small budget and simple plan, and then anticipate spending 3 times as much! It always seems to end up that way. You've already saved a bundle getting a rust free cab - rust repair is expensive. Spent 18 months at MCAS Yuma decades ago, I know what you mean about drier than hell. Great for rust free sheet metal, not so friendly for humans.
60-66 Nut
Welcome to the board
Registered Loser
Nice find! In case you don't know yet, you should check out www.6066gmcguy.org. Tons of info on there.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
Picture of the firewall painted black.
![]() Join Date: Nov 2008
Welcome to the boards !!! Looking Good , Keep the pictures coming ..
Shloooooong bed member #2
Welcome from West Tn.
Nice rig you got there. Ooh. and lets see some pictures of your dads truck.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
I will work on them pictures of my Dad's truck.
Here are some new pics. I put the I6 250 from Chevyguys in the truck yesterday. I did some cleanup and paint. It looks good. I need a new coil and a little more degreaser but, it looks great otherwise. Now I need to rewire under the dash and I need a new engine harness. After that, then we have a brake job then register this bad boy. hopefully I can drive it once a week to work by November. That is the goal. Finally, I will just peck at it until I reach perfection. I am glad I got a good engine that is half the battle.
Made some progress on the 64 yesterday.
1. Put the starter in the engine after having it checked 2. messed with the engine harness 3. Put on Powder coated Battery Tray 4. Put on the power steering bracket and pump. 5. Put radiator support back on after rust cleaning and paint 6. Put a little satin black paint on the passenger side just to see if I like it. 7. bought a new horn relay 8. Had the ingnition switch tested and lubed up 9. trying to figure out why she wont start 10. Added 6 blade fan instead of 5 Hoping to get gas tank and seat soon. Need to do brakes and get truck running then I will be going straight to the DMV to get plates and registration. Then I will peck at the truck until I am satisfied. Last edited by Rusteeze64GB; 11-04-2009 at 06:56 PM. Reason: adding |
#15 |
So, I am now onto the brakes. Truck is running good. Need tune up but, it starts on the first key turn, everytime.
#16 |
absolutely bleed the brakes - it will be an improvement - explanation tells me you have air in the lines, especially if you literally had a dry master cylinder.
if you have vacuum lines not connected than you should have a helluva air leak - which would degrade engine performance (you mentioned thinking you need a tune up) and would not engage the booster so you would have a firm pedal (like when your car stalls and you apply the brakes) but the disconnected vacuum lines shouldnt cause pedal mash - thats air IMO |
#17 |
Well it has been a while since I have updated this thing. I tell you, man you think you can do this for 700-1000 and you end up 1400-2000 into in a heart beat. Well to repeat my story briefly. I bought the truck for $975 1964 GMC. I have done all of my own work, including the used but nice running engine from a new found friend on the forum. The 975 came with Surface rust and a siezed 235. I knocked that rust off and put a 250 in then got into my project. I am not going to lie I have cut corners. What I mean by cut corners is used parts in better condition than I had and not ordered factory original parts. I am a detail oriented guy so I know that time and TLC would go a long way. I want to say thanks to Chevyguys for the help and parts he provided. This board has helped me in so many ways.
So, I only wanted a decent twice a week driver that would be fun to take for a drive on the weekend or to a car show to park and wander like a lost soul wishing I had a 77 firebird. ![]() ![]() Rest of to do list: Interior $50.00 Black Suede for Arm Rests $15.00 Tires $350.00 Side Mirrors $50.00 Brake and Blinker Bulbs $15.00 and I am sure other stuff will pop up and my bill will be more. I will send more pics when I am street legal and driving. Probably around July - August. ![]() ![]() |
#18 |
UCA63
Looking great Rusteeze
Got to love it when elbow grease pays dividends keep up the good work T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#19 |
Gotta' paint my baby black like that! That can't possibly be a rattle can job? You do it yourself?
ABOZ |
#20 |
One foot in front of the other
![]() Join Date: Aug 2008
Looks great
#21 |
That is a rattle can job. I took all the rust off and I used a real expensive primer about $15 per can. I used 3 cans. The devil is in the details
#22 |
Redneck Hillbilly
I did a rattle can job on my '79 Camaro with the same Rustoleum satin black, and it turned out great, even added some satin white GM style stripes to it. Cool project you got going there.
#23 |
Resistance is Futile
Nice work!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#24 |
fan of "Butters" Stotch
Even if you 2K into it when you are done, you are still doing good. Cheap fun-I like it!
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
#25 |
good work.
