427 bbc hp guesstimate
I'm currently putting together a 427 big block for my '74 and would like to know how much hp yall think it will make?the specs are these.
454 block bored 30 over with 427 internals. Gm crank and rods(stock stroke) trw dome top pistons part#l2239nf-30 comp cams magnum 292 cam 049 heads with 2.19/1.88 valves no port work comp cams magnum roller rockers holley dominator intake i plan on using a 850 dp carb? Comp ratio not sure but i think it should be @ 10.5 to 11.the heads were milled a little but not sure how much,the block was also decked but not sure either i know it wasn't zero decked though.i know its hard to guess with out comp ratio but i would just like opinions from yall and wat yall think about the combo thanks a lot. |
![]() Join Date: Jul 2007
Re: 427 bbc hp guesstimate
425-450?
motor exploder
i outta have some good top-end! I don't think 450hp is too far off.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#4 | |
Here's mine: 454 .030 over with stock crank and rods Speed-Pro Pistons Comp Cam 292H (.550 lift 244 @ .050 on intake and exhaust) Edelbrock Performer RPM Marine Heads (2.25 int 1.89 ex, 110cc chambers, 290cc flow) Edelbrock Performer RPM Air Gap Intake - Nascar edition ![]() Comp Aluminum full roller rocker 1.7 850 Carb - considering Mighty Demon Not sure on deck height but it's not zero. Compression ratio with these heads and pistions is 10:2 on paper. Any guess on what this will make??
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
motor exploder
AusTx your combo is even closer to the motor i'm building
![]() Glad someone else is on board with the E'brock Marine heads! I got a set myself, here's my combo (and yes, those heads will make a big difference over the GM 049's). AusTx, are your Speed Pro's domed? The only domed piston I found recommended for the semi-closed chamber E'Brocks are made by SRP (JE). I'm gonna run a set in my 468, they are -23cc small domed, and come out to around 10.1 with a .039" thick head gasket. My block is going to the machine shop tomorrow. here are my hard parts E'Brock BBC Oval port Marine Heads, Crower valvesprings E'Brock Air Gap intake Crane full roller rockers Comp Magnum pushrods comp X4 278 cam, 234/244 duration, .564/.575 lift Holley 870 Street Avenger, 1" Moroso open spacer SRP forged slugs Stock 'truck' rods (polished beams, ARP bolts) Stock crank, ARP studs in bottom end Check out this build in car craft: http://www.carcraft.com/techarticles...evy/index.html I was hoping to get at least the 530hp they got with the dual plane, maybe more since I'm running a little more cam, and bigger intake valves.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 09-30-2009 at 10:20 AM. Reason: typo on the piston dome size - duh! |
#6 | |
http://www.summitracing.com/parts/STL-H693CP/ I just got my heads back today and hope to check piston/valve clearance sometime in the next few days. Your SRPs are -13cc piston head volume? Do you think the -22cc will be a problem?
motor exploder
I wish I could tell you that! The EB heads are a 'semi-open' chamber at only 110cc. Not saying the SRP's are th ONLY slugs that work (the article I posted used Speed Pro's) but 22cc's is a good sized dome with a small chamber head. All I can say is measure, measure, measure test fit and measure again! No one wants to slam pistons into a valve! I am curious to see what you find out. I'm taking my block in this week for machine work, so hopefully I'll be putting my junk back together soon and can let you know what I find.
![]() Join Date: Dec 2008
With that small hydrolic cam no way will you see 450-475hp
to get into the 500hp you need to go with either solid lift cam or a full roller cam and when you do that you better get a set of H-beam rods (4130 steal) and a good set of forged pistons if you want it to last My dad lives in east texas if you want to get any advice a real estimates he build about 30 high performance motors a year let me know |
man their is so many variables to take into effect... where do you live? volumetric efficincency, if you was to take best case scenario i would personaly say 450-475 but to the wheels is a different case, if you want to know those numbers what trans are you running? and theirs allways the tuning capabilities of yourself or whoever is doing it, timing, jetting... you want solid numbers DYNO IT AND TUNE IT. its saves the hassle of street tuning and you know for sure what it makes. just my half cent worth.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
Thanks for yalls opinions guys!i was hoping for like 500 maybe but these numbers dont sound bad at all.AND BESIDES I KNOW THIS MOTOR WILL MAKE MORE THAN ENOUGH TORQUE TO FRY SOME TIRES ON THE STREETS.
#11 | |
Have the heads ported and that should get you close if not over. (if done properly) |
before i installed the heads on the block i asked that question here, if i should get the heads ported or not and almost everybody told that it wouldn't be worth it. That i wouldn't even notice the gains if any so i didn't port them.
motor exploder
and that is true. the only way to really port heads is by doing it with a flowbench and having someone who knows the art AND science behind it. Don't get me wrong, there's nothing wrong with a backyard done gasket match and light cleanup/bowl blend, but a full on port job is a different animal, and is the only way to get real measureable results. You can't just grind away with a dremel and expect 50hp when you're done. The 049's are good heads and I think you have a solid combo put together. As said before, invest some time in tuning and setup and you'll be happy in the end.
#14 | |
#15 | |
Properly ported (not a backyard hack job) heads are worth it. Certainly the 049 and 781's, they pick up nice power from minor clean up. You could gain up to 50hp for sure. |
#16 |
#17 |
Listen, I'm located in Canada and there are a couple in town that do decent work. I have no clue who would be able to work on your heads in your area. Don't spend a fortune just have them cleaned up.
OR bolt 'em on and upgrade to some nice aluminum ones later. |
#18 |
well i already have the heads torqued on the block so yeah i guess i could upgrade to some better ones later on.
