09-29-2009, 09:03 PM | #1 |
2-Piece Driveshaft
I am running a LS1 w/4L65E and a '72 rearend in a 67 chevy chassis. I am planning on using a 2 piece driveshaft. I have read all the threads on how to do it and am still not 100%. Looking at the engine it is going to have a downward slope, can I run the front driveshaft parallel to the frame back to the center crossmember then let the drop in the rear allow the rear driveshaft to angle up.
I know if you are using a single driveshaft you want like 3 degree down eng and 3 degree up rearend for proper u-joint lubrication. I measured from the end of the trans housing to the center of the center crossmember at 15" and then from there to the pinion yoke at 41". Any idea if a late model 2-piece driveshaft would work. Any help would be appreciated.
1972 Blazer body...need to get a thread started for the rest of the story |
09-30-2009, 01:11 AM | #2 | |
Re: 2-Piece Driveshaft
The front shaft should have 1*-1-1/2* true operating angle then match the rear end to this angle (trans yoke + 1*-1-1/2*) Here's a link to some good driveline info, multiple shafts start on page 13.
http://www.roadranger.com/ecm/idcplg...ILE&dID=137499
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
09-30-2009, 06:55 PM | #3 |
Fixit-p, Thanx a lot. That is the best description I have seen so far and I actually understood it. LOL
09-30-2009, 07:19 PM | #4 |
10-01-2009, 10:17 AM | #5 | |
Glad to help, That is a good resource for sure.
