Old 09-29-2009, 11:41 PM   #1
Eagar1
Prop valve line routing
Getting ready to mount my brake booster/mastcyl/propvalve, thought I knew how it should be routed then I came across this picture, on a 70's truck that looks like the same mast cylinder I have, and a similar valve. The routing in the picture looks backwards to me. I have a valve off a 75 C10 that was disc/drum. It is just like the diagram shown. Also wondering what the difference is if I plug the top front hole of the prop valve for the front brake(right front) and just T off the lower one(left front) instead of running two seperate lines? Also is there any reason why I couldn't run the rear brake line down the driver's side? Seems odd to run it over the front crossmember for no reason.
Eagar1 is offline   Reply With Quote
Old 09-30-2009, 12:18 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Prop valve line routing
I used a 1975 crossmember, suspension, brakes, etc. in my 1960 GMC. The routing on my proportioning valve is exactly like that shown in the diagram. I think the routing in the photo is actualy similar, other than the valve appears to be mounted backward, with the front side of the master cylinder connecting to the rear port on the valve. There were at least 3 styles of proportioning valves. The original (perhaps 1968?) was a small cylinder style. The 2nd design looked like the photo, and later the solid machined block type. You can certainly run the line down the driver side if you prefer, the braking system doesn't care. You can also mount the valve remotely if you prefer to clean up the booster area. It makes it easier to change spark plugs and looks better. Mine is mounted on the crossmember under the oil pan behind the motor mount, which allows for nice looking lines in the engine compartment:
Old 10-01-2009, 09:45 PM   #3
Eagar1
Nice set up Mark, think I will do something similar, I will post pics once I figure it out.
Old 01-20-2012, 09:52 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I know this is an old thread, and there are numerous duplicate threads asking brake line routing, but this one had a pic a the combination valve identifying what went where.
Thanks.
Here is the pic from LMC that might also help others:
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-20-2012, 09:56 PM   #5
LostMy65
LostMy65's Avatar
related question:
why is there a separate connection for left and right front brakes?
Old 01-20-2012, 11:12 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
I believe there is a metering valve in the end of the block to control the bias between front left/right.
http://www.mpbrakes.com/technical-su...igurations.cfm good info here.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
