Nitrous Systems ?
I am planning on adding a 200-250 shot just for fun
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
Re: Nitrous Systems ?
foggers are generally used for a few reasons, a fogger can support more stages at a larger flow. and foggers have a better distribution into each individual runner for better atomization. generally most guys that run foggers are running multiple stages of 500hp "shots" for your scenario i would go with a plate system, theirs alot of good plate systems out now for what your trying to do the NOS big shot plate system is a good and inexpensive plate system, or the NX Gemini wich is what i run, or if you can afford it i recommend going with the Wilson pro flo plate system, the plate has burst plates in it for back fires the solenoids are all rebuild-able and billet and the solenoid brackets they have are awesome for keeping it clean.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
On a budget like Fred Sanford
The biggest advantage with foggers over plates is the amount of fine tuning they provide. You can tune each individual cylinder on both nitrous and fuel sides. If you've got a hot cylinder you can pull some no2 jet out. With a plate you pretty much have to tune the whole system off the "worst" cylinder. I run a fogger setup on my camaro (LSx motor) with a 200 shot.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Wilson is to much, i would go with a fogger for that price. I have a Dominator intake and an adaptor for 4150 carb. not sure if setting a plate on the top or bottom will make a diffrence. Thinking the higher it is, the better it will dispurse.
mini truck racer
At 200-250 id go with a NOS cheater/Edelbrock plate . That would give you the ability to go smaller if you wanted . The tune ups are easy and proven . The plate is alot easier to install .
A fogger looks cooler and will hit the tires softer than a plate . The manifold also needs to be set up in a mill for the holes to be drilled so it will look semetrical piping wise . Tuning for a fogger is alot more precise .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 10-02-2009 at 12:52 PM. |
#6 | |
Hay Team!!
![]() Join Date: Jun 2003
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
Wilson makes great nitrous stuff but I would avoid the plate with the burst panels. I have a friend that has had trouble with them and he runs NA most of the time. If you are gonna run a plate you might want to look at the Speedtech diffusor plate. Thats what I had on my truck at Pass Time.
Mine will have a fogger with big jets next time out.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I agree with hotrod80 the plate is a lot easier and more simple to install but the fogger looks a lot more cool.
