Old 10-02-2009, 02:04 PM   #1
Hawker7
Timing Question
I have a 350 crate motor that is all stock running a edelbrock1406 carb, and a HEI Skip White distributor. When I first set the timing I had it set at 12 degrees initial and while it idled OK, it would stumble when trying to accelerate. I then advanced the timing till it would run decent and now it is at 24 degrees initial. Also, the total advance timing is 40 degrees at 2,000 RPM’s. Something seems way off. When I first set the motor up I did verify that TDC was 0 degrees on the timing tab. Any ideas? David
Hawker7 is offline   Reply With Quote
Old 10-02-2009, 02:20 PM   #2
mclairmo
Re: Timing Question
New or old balancer? Verify it has not slipped. Are these numbers with the vacuum advance can plugged or not?
mclairmo is offline   Reply With Quote
Old 10-02-2009, 02:23 PM   #3
Hawker7
Re: Timing Question
New balancer from Summitt. This is with the vacuum plugged.
Old 10-02-2009, 02:21 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Timing Question
That is very possible. I have a 350 with a mild cam in it. I had a hot rod builder out here go through and re-arch the distributor and time it properly for the cam. The base timing was off the scale! I'm guessing almost 30°!! Total advance was around 43 - 44°. Oh, and NO vacuum advance!! All centrifugal... When he did that, my low end probably tripled in power, the mileage went up about 10 - 12% and it ran better than you could imagine. With no choke, I could get in it when it was around freezing, pump the gas once, start it and it ran!
So I'm not saying yours IS correct, but it MAY be correct.
69GMCLonghorn is offline   Reply With Quote
Old 10-02-2009, 02:26 PM   #5
Hawker7
Re: Timing Question
It does start up with just a tap of the starter and runs nice. Since I only have 50 miles on the motor I have not ran it hard so I can't say for sure how much power it has.
Old 10-02-2009, 03:47 PM   #6
Mertz
Re: Timing Question
I set mine up for 14 base and 37 with mechanical and a total of 55 at 3000 rpm. It seems to work the best at that setting. I have a MSD ready to run distributor that I had to change the springs and bushing to get it to 37. Vacuum advance is not adjustable. I am also running an Edelbrock carb and EPS manifold with a 1" spacer.
Mertz is offline   Reply With Quote
Old 10-02-2009, 05:51 PM   #7
LONGHAIR
Re: Timing Question
37 degrees of centrifugal timing seems a bit out-there? but then so does running w/o vacuum advance on a street vehicle.
(All of that initial advance would be required to make it run w/o having the vacuum advance connected).....but it doen't make it right.
The only reason to run w/o vacuum advance is in a totally wide open throttle situation like drag racing.
Assuming that the distributor is working properly...there is no real reason to look at the timing as the source of your stumble. The timing is "close enough" for timing to not be your problem, it is more likely carburetion/fuel. The timing may not be perfect, but it has to be off pretty badly to cause this kind of thing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-02-2009, 06:01 PM   #8
Mertz
Re: Timing Question
Actually that is base and mechanical for a total of 37. It would be 23 mechanical. I am also running my vacuum advance off manifold vacuum. The truck runs great. I never have a problem starting. It normally starts with the first touch of the key. Power is good but found more by changing the rods in the carb but it was using to much gas. I am now trying a quadajet to try to imporve my mileage but I think I have a warped stock aluminum egr manifold because it is not running right. It falls flat on its face when I lay on the throttle with a Jet Stage 2 and doesn't do much better with a stock Q-jet. I am going to try the Edelbrock on the manifold to confirm it is not the carb.
Old 10-02-2009, 06:56 PM   #9
Hawker7
Re: Timing Question
I'm not running it with no vacuum advance. Only to time it.
Old 10-03-2009, 11:12 AM   #10
LONGHAIR
Re: Timing Question
Sorry, I didn't mean to confuse, I was refering to 69GMCLonghorn about the lack of vacuum advance.
You are correct in timing w/ the vacuum advance disconnected.
Well an initial setting of 14 plus 23 centrifugal would indeed total 37, I missed it in the wording.....I was confused by the "total" of 55...? I am assuming that this would be the "theoretical" vacuum added?....because it won't. These things really don't "just add up" The odds of you traveling down the road @ 3000 RPM and still having enough vacuum to pull in the advance are pretty slim. About the only time that happens is when you sharply close the throttle....you might make it happen "free-revving" in the garage, but it won't happen under the load of moving the truck.
Old 10-03-2009, 12:58 PM   #11
Richard H.
Spanked once
Richard H.'s Avatar
Re: Timing Question
Hawker, I have the same set up in my '55 and had the same issue.
Final result 11+ initial and got the metering kit for the 1406 and used the smallest rods I could use without changing the jets , at least that was my sweet spot. Also changed the primary pump setting.
It just wasn't getting enough fuel.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 10-02-2009, 10:27 PM   #12
highperf4x4
Re: Timing Question
All of these timing numbers are off the scale.
You shouldn't be running more than 37 degrees TOTAL advance at 3000rpm.
My base advance is 10 degrees without vacum. Even with Super Unleaded I get a ping if I try to advance it any further.
When you set your initial timing with the vacum advance disconnected and plugged off are you sure your engine is idling around 800-1000 rpm?
If not then you're getting some mechanical advance unless your springs are extremely stiff.
I'd run it down to a machine/performance shop and let someone set the timing for you with an inductive timing light. Or cough up about 300.00 and get your own.
highperf4x4 is offline   Reply With Quote
Old 10-03-2009, 02:00 AM   #13
69 longhorn
Re: Timing Question
I like to shoot for about a 34 degree TOTAL @ 3000 rpms (vac can unhooked & plugged) on a 9.5- 10 to 1 pump fuel engine. Add 10 to 12 degrees vac advance, & you are in the ball park. some like a little more, some a little less, depending on the combo(comp ratio,cam ,ect). a lot of those old small blocks will pull tween 48-52 degrees (no load, with the vac can hooked up), with no problems. if it spark rattles @ part throttle. it has too much vac advance....spark rattle @ WOT , too much initial/mechanical advance. best of luck,crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-03-2009, 03:18 AM   #14
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Timing Question
Do you have a vacuum gauge? Ported vacuum should be about 20" at 3500RPM. If it's much lower or the gauge needle wiggles at idle, then you have a problem.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-18-2009, 10:55 PM   #15
mtdave2
newly minted old timer
mtdave2's Avatar
Re: Timing Question
huh, well, this may be my prob. i was planning on getting some new plugs tomorrow. i called jegs to ask what plug was recomended for the head i bought. i am having timing issues. had to advance the hell out of the timing like you said.. perhaps the plugs will help
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
