10-04-2009, 04:04 PM | #1 |
door wont open
I am trying to remove my passenger door. Keeping the door closed, I removed the bolts from the hinges and then tried to open the door and remove it. It would not open so I tightened the hinges back up and it still wont open. The door was working fine prior to loosening the hinges. Anybody have any suggestions?
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
10-04-2009, 04:13 PM | #2 |
Man of Mini-Talents
Re: door wont open
Did you give it a good pull? There's no direct connection between the hinges and the opener. My guess the full weight of the door is on the striker and it's going to take more force than it normally would.
10-04-2009, 04:42 PM | #3 |
Car Knocker
Re: door wont open
Door is locked. or you didn't pull hard enough.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
10-04-2009, 04:44 PM | #4 |
Old Skool Club
Re: door wont open
BA screwdriver, inserted into the gap between the door and the fender may be all you need.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
10-04-2009, 08:56 PM | #5 |
I am a Referee of life.
Re: door wont open
You might also try lifting up on it some.Sometimes they wear a bit and droop so the latch doesn't release very well.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-04-2009, 08:59 PM | #6 |
Re: door wont open
I've tried everything, locked, unlocked, lifted up on it, done everything but hook a come-a-long to it and jerk the dam thing open. I really dont want to pry on anything and cause any body damage.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 Last edited by PipsC10; 10-04-2009 at 08:59 PM. Reason: spelling |
10-04-2009, 09:08 PM | #7 |
Re: door wont open
Does the handle function? Try and have a buddy push from the inside while holding the latch open . I had to kick my XJ open from the inside once. Not suggested but I had no one to hold the handle open.
72 k20 Cheyenne Super 350 Turbo 400 Dana 44 Front / 60 Rear NP 208. 315 70 17 Hummer H2 wheels. Black. |
10-04-2009, 10:21 PM | #8 |
Re: door wont open
yes the handle does operate, I looked in between the door and saw it was still functional. I think once I get a second hand I will have someone hold the handle while I kick it from the inside. Hopefully that works.
10-04-2009, 11:51 PM | #9 |
70 Chevrolet=Obsession
Re: door wont open
Please clear something up for me. Why is it so important to try removing the door when it's closed? Are you parked next to a wall or something?
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
10-05-2009, 11:09 AM | #10 |
Re: door wont open
I was by myself, did not have anything to prop it up while I was removing the hinges.
10-05-2009, 01:25 PM | #11 |
Redefining LowBudget
Re: door wont open
open the window and use the inside handle sometimes that will work better.........
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
