truck rearend and spings fit a blazer?
my buddy has an 86 blazer (i kno this is the worng forum but i cant get any posts in the other blazer forum) and the rear springs are jacked up! will the rear end and springs out of a 1/2 ton truck fit? and if so what year trucks?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Oh..never mind....
Re: truck rearend and spings fit a blazer?
The rear springs are the same length, so the Should bolt right in. If I remember right, the mounting perches for the '73 and up rear ends are farther apart. So to use the newer rear end, you would need to put new repositioned perches on for the rear end to fit. Also, I think the newer rear ends are a little wider, but you might want to measure everything to confirm this.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
He is talking about an '86. Any '73 - '87 half ton springs and axle will work. If you use a 12 bolt ('73 - '80) instead of a 10 bolt like the '86 came with, you will need a conversion u-joint for the rear axle.
Tim |
