10-06-2009, 03:47 PM | #1 |
9 Inch Rearend question
I haven't posted in sometime, I have got a ton done and need to post pics. Maybe tomorrow, I have to work late tonight.
For the question. I know that a 9 inch will never bolt in without changing the brackets, but has anyone found one that has either a 5 on 5 or 5 on 4-3/4 lug pattern and is the correct width or maybe a few inches narrower? Also, is the search function broke? I can get it to do anything. Thanks
Don't let my username fool you, I have become brand blind. Cool is cool, period. 1965 C-10 - "Whipping Post" 1958 Biscayne - "Ruby" 1961 IH Scout 80 - "Gaucho" (My wife's new project) 1938 Chevy - unstarted project. |
10-06-2009, 06:18 PM | #2 |
Re: 9 Inch Rearend question
I got one out of a 73 Mercury Marquis. Has a 5x5 bolt pattern.
10-06-2009, 11:09 PM | #3 |
I got one out of a late 70's Lincoln Versalies. These also have disc brakes. They are fairly common to find at swap meets.
I love the smell of lead paint! |
10-07-2009, 05:09 PM | #4 |
How do you set the pinion angle for these rearends? Is it possible to set the required angle with the bed off(without the weight of the truck).
10-07-2009, 05:47 PM | #5 |
Most guys I know that have done this swap just set the pinion back to the stock setting for the 12-bolt. They put the pinion yoke @ plumb & measure the angle of the rear brackets on the 12-bolt rear. Cut the truck arm brackets off (or get new ones). Set the 9" housing w/the pinion yoke @ plumb & attach the brackets @ the same angle as they were on the 12-bolt. Tack them in place. Re-check the angles & if everything is good, weld them up.
