Old 10-07-2009, 03:00 PM   #1
snowblind
snowblind's Avatar
72 Jimmy: Project Knuckledragger mountain commuter
Hi everyone.
I bought a 72 Jimmy a couple of days ago. My first GM truck!
I'll be doing sort of "rolling restoration" over the next few months. It's not my daily driver but I do need to use it 3 or 4 days per week. The end goal is a smooth riding pavement/gravel road truck to cruise around town, take short highway trips and drive up to go snowboarding 20-40 times per winter.
Currently sitting on 33x1250 BFGs and a 2" lift with HD springs on the front and 2" square pipe blocks at the back. It needs a tune up to pass emissions but after that I'll be getting busy with rust repair and bodywork...
Here are some pics from the PO.
Matt
snowblind is offline   Reply With Quote
Old 10-07-2009, 04:17 PM   #2
big dump
big dump's Avatar
Re: New Member - 72 Jimmy: Project Knuckledragger mountain commuter
Cool, should make a nice driver. Welcome to the board!
big dump is offline   Reply With Quote
Old 10-07-2009, 04:32 PM   #3
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Welcome to the board!! I think I might have an upper grill trim for you if you need one. but it looks like you have a pretty solid rig.
NTR72GMC is offline   Reply With Quote
Old 10-07-2009, 04:47 PM   #4
vtblazer
vtblazer's Avatar
Welcome to the board, check out those torsion boxes, looks like it had saddle tanks once upon a time.
vtblazer is offline   Reply With Quote
Old 10-07-2009, 05:09 PM   #5
truckster
truckster's Avatar
I think that's one I was looking at on KSL. My wife said my Blazer doesn't need a brother right now.
It looks like you did pretty well. Welcome to the board.
truckster is offline   Reply With Quote
Old 10-07-2009, 05:24 PM   #6
snowblind
snowblind's Avatar
Thanks but I already have an extra grill and that trim piece.
Yep. The tanks are gone but that whole area is rusty. I'll be ordering repair pieces this week.
It was on KSL. It has some good points and some bad... I just found out that the trans is leaking fluid into the transfer case so that would be a bad point.
Are there many Utah owners on this board? I'ld love to get together and share ideas.
Matt
Old 10-07-2009, 06:46 PM   #7
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
There are a few of us here in Utah.
Old 10-08-2009, 04:16 PM   #8
ChadGiles70
I'm up in Logan but would love to share Ideas.
ChadGiles70 is offline   Reply With Quote
Old 10-08-2009, 05:38 PM   #9
snowblind
snowblind's Avatar
Springs and things
Good to see some Utah folks. I'm on the lookout for a GMC stamped tailgate and a few other things if you guys know of any parts stashes...
I ordered some custom springs today from Alcan Spring. Based on the project goals I went with stock height and an "EZ-ride" spring pack. Alcan recommended Bilstein shocks so I think I'll give them a try.
In other news my mechanic got it to pass emissions but he had to tune it on the dyno to just barely pass. I might be looking into fuel injection when inspection comes around next year... Then on the drive back from the test the throttle cable broke and we can't get another until Friday afternoon!
Best regards,
Matt Crawley
Old 10-08-2009, 06:18 PM   #10
swyfor5
swyfor5's Avatar
Welcome aboard and good luck! Keep us posted, and remember we love pic's!
swyfor5 is offline   Reply With Quote
Old 10-08-2009, 09:52 PM   #11
Big J
Its lookin' like a Blazer!
Big J's Avatar
Looks like a great start. That'll make a classy rig to haul your snow boarding gear in.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 10-13-2009, 09:16 AM   #12
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Springs and things
Matt;
Which county are you in? We have seriously been wanting to move up that way, but being from Ca. where these things are smog exempt, I am worried about smogging mine (there isnt a C.A.R.B. legal part on my Jimmy). Its kind of a bummer because Ill bet it would show numbers that were better than stock original... it just would in no way pass the visual.
Thanks,
Tom
ps... my son lives in Syracuse.
Tom Vogel is offline   Reply With Quote
Old 10-13-2009, 10:50 AM   #13
snowblind
snowblind's Avatar
I'm in Salt Lake County. I think Salt Lake and Davis County require smog and I think all counties require safety. Not sure if any other counties require safety. There are minimal "visual" inspections to pass and then a run on the dyno. No need for CARB stickers or anything like that. If it passes the emissions sniffer you pretty much pass.
They are tougher on more modern cars. I have been denied for not having a charcoal canister on a 91 Toyota but my '72 has no EGR or canister or anything like that and passed fine due to the "age requirements". On the smog test my truck blew 1200ppm and is allowed up to 3000ppm of NO. Our 08 VW passat blew 2ppm!
Matt
Matt;
Thanks,
Tom
Old 10-16-2009, 02:30 AM   #14
truckster
truckster's Avatar
Matt
Weber and Utah Counties also require emissions tests. Statewide anything over eight years old requires an annual safety inspection as well.
Old 10-09-2009, 01:23 AM   #15
71 TopCat
PLAY HARD.....OR DONT PLAY!
71 TopCat's Avatar
Welcome Aboard!
When something breaks... Remember that it can always be worse...(what ever that supposed to means)
IF YOU DONT HURT..........YOU NOT TRYING HARD ENOUGH.
71 CST BLAZER 4X4, 1 TON, 496 STROKER/TH400, NP205, D44/14BOLT LOCKER, 35" BFG'S,...
68 C30 292 LB (POP'S BOUGHT IT BRAN NEW)
05 2500 4X4 DURAMAX CREWCAB
79 FLH HD 95CI EVO
:b69
71 TopCat is offline   Reply With Quote
Old 10-09-2009, 08:30 AM   #16
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
welcome from another jimmy owner
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-09-2009, 07:35 PM   #17
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Welcome Snowblind, also from another K5 Jimmy owner. That tailgate looks repairable in the pics. Is the bottom rusted out? Around here you just cant find half way decent GMC tailgates and Chevy ones are getting harder to find all the time. Cool project and a rolling restoration is the way to go in my opinion.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 10-09-2009, 07:51 PM   #18
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Your tailgate looks pretty clean whats wrong with it?
Old 10-09-2009, 09:38 PM   #19
truckster
truckster's Avatar
I wouldn't worry too much about the trans leaking into the transfer case unless it's really bad. The transfer case can apparently operate with dexron in it.
Old 10-10-2009, 09:34 PM   #20
AJs72K5
AJs72K5's Avatar
The rear tranny seal leaking is pretty common. Tranny fluid won't cause any harm to your 205. However, keep in mind that if the tcase is fully of tranny fluid, then the fluid that's supposed to be in the tranny isn't there. In other words, keep an eye on the fluid level in your tranny.
And nice choice on the Alcans. I love 'em when my rig is together long enough to drive it. Hard to go wrong with Alcans and Bilsteins.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 10-12-2009, 11:23 AM   #21
snowblind
snowblind's Avatar
You can't really see in the pics but the whole middle of the tailgate is dented in and there are a couple of splits around the handle. It's definitely repairable but I figured I would ask the locals first.
Progress Update: New front Bilsteins are in. The interior is stripped of everything but the seats, instruments and heater. I have new calipers, pads, u-joints, ball joints, steering box seal kit ready to install this week. I need to order patch panels today in hope of getting into the body shop next monday. I'll post an update and more photos soon.
Old 10-12-2009, 11:31 AM   #22
jaros44sr
jaros44sr's Avatar
if you do decide to scrap the tailgate, cut out the GMC embossed logo for me! All I have is a crappy chevy logo
Nice project, Im subscribed
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-12-2009, 02:22 PM   #23
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
What body shop are you taking it to?
Old 10-12-2009, 06:53 PM   #24
snowblind
snowblind's Avatar
I'm talking to the Maaco in SLC right now just because no one else would touch it. The Maaco guy I met with was pretty cool and will willing to work with me to keep the costs down.
I'm buying all the patch panels and doing a lot of the prep. Maaco will do the welding and paint. Do you have any other body shops that you would recommend?
Old 10-12-2009, 07:00 PM   #25
snowblind
snowblind's Avatar
Where did my metal go?
Here are some pics of the rocker areas. I'm no expert but it looks like there might be something missing... The PO had some leaky, rusty "saddle tanks" and I'm guessing that the frame/body supports were cut to fit them.
Does anyone have any photos of what a healthy Jimmy rocker area looks like?
Passenger side:
Driver side:
Matt
