10-08-2009, 05:45 AM | #1 |
6/8 drop
Is a 6/8 drop a modified 5/7 or 4/6 or someone sells a 6/8.How do i get that much drop with out bags.
10-08-2009, 06:11 AM | #2 |
Re: 6/8 drop
Whar year truck
70 SWB STEPSIDE 70 BLAZER 09 challenger |
10-08-2009, 12:31 PM | #3 |
It'd be alot cooler if you did
Re: 6/8 drop
10-08-2009, 08:06 AM | #4 |
vw guy & now c-10 guy
Re: 6/8 drop
well I'm doing a 5.5/7- which is 2.5" drop spindles and 3" drop springs up front, and 5" drop springs and 2" drop blocks out back. From what I gathered, this is just about as far down as I could go static, and still be able to turn the front wheels. lol - will be riding on 15x7s and 225/75r15 all 4 corners
10-08-2009, 11:31 AM | #5 |
Re: 6/8 drop
Im doing a 4.5/7. 2.5" drop spindles and 2" springs in the front. The rear will be 2" drop trailing arms from Porterbuilt and 5" springs. It hsould be on within a few weeks and Ill get pics and let you know. hopefully the 255/40/20 front tires will work.
10-08-2009, 02:06 PM | #6 | |
Wide n'Low
Re: 6/8 drop
Mike J, I was wondering about your tire size and the amount of space around the tire and the wheel opening.. Any pics of your setup. I ask because if I am correct, your tires are about 28.3 inches tall, and I am looking to do the same drop, but currently have a set of 295/50 15 tires on rallye's and wondered how odd it might look since they are only 26.7 inches tall.. thanks, Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
10-08-2009, 03:09 PM | #7 |
6.0 powered square
Re: 6/8 drop
for a 6-8 you'll want 3" spindles or 3" drop control arms but warn you they almost twice the price as spindles, 3 drop springs or stock springs cut 1 1/2 coils off unless there really week then just a coil, and if you already have drop springs you can cut those to, for the rear a flip kit, drop shackles, and either the lack of leafs, or large about of leafs should get you down to 8 in the rear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-08-2009, 04:27 PM | #8 |
Re: 6/8 drop
I didn't see it mentioned.... What year truck are we discussing?
10-08-2009, 04:40 PM | #9 |
Re: 6/8 drop
10-08-2009, 07:40 PM | #10 |
Happy to be here
Re: 6/8 drop
From a previous post by Big Kris- "Brought my 83 shoebox home to try and get some work done under the hood this week while im on vacaton. "
10-08-2009, 09:30 PM | #11 |
Re: 6/8 drop
Hey Drew, Sorry but I can't really tell you yet- I'm lazy and the truck is still in pieces. I'm hoping it's gonna be just about perfect...
10-09-2009, 12:55 AM | #12 |
Re: 6/8 drop
Sorry i didn't mention but yes the year is a 83 and my dad has a 85.thinking of a alternative route before i try to bag her.Talked to Nate and airride tech,but i like the stance of that yellow and white c10 done by Hills Hotrods.Will i have a problem running 20's and will it handel very nice or just ride rough?
10-08-2009, 07:31 PM | #13 |
Re: 6/8 drop
ive always ran super low slatic drops, i never use spindles on super low drops, just drop LCA and springs(cut of course)
10-09-2009, 01:13 AM | #14 |
6.0 powered square
Re: 6/8 drop
if you run good quality parts and shocks you should be fine and a also a tire larger than rubber band helps for shocks I wouldn't run toxics there bouncy and don't last very long
10-09-2009, 02:09 AM | #15 |
Re: 6/8 drop
THanks.And a firm responsive ride is what i'm looking for,not that soft floaty unstable feel it has now.
