Old 10-08-2009, 04:16 PM   #1
UltraBlue71
UltraBlue71's Avatar
Storing A Truck
I have to store my 71 LWB for 3-4 years, (going overseas for another long tour)does anyone have any suggestions on what I should do to my truck prior to slamming the storage unit door? Stabil wont last that long so a complete fuel tank drain is in order I imagine, should I drain the antifreeze too? What about engine oil other fluids, etc? Put it up on jackstands? I was just trying to make as little work as possible for myself when I get back and get to use it again.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 10-08-2009, 05:06 PM   #2
big_al_71
big_al_71's Avatar
Re: Storing A Truck
This is what I would do:
Put synthetic oil in the motor....
Put the truck on jackstands.....
Drain all the fuel.........
Put a cover on it........
Make sure your insurance is paid in full just if something happens....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-08-2009, 05:16 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Storing A Truck
I think if I was to store it that long I would fog the motor like it was a boat motor this will coat the holes with a layer of oil to keep them clean might even crack the valve cover and loosen up the rockers to get the load off springs
take out the battery
get a bag of dry pellets (the stuff they put in your pill bottles only bigger)
steel wool the tail pipe
speedy dry piles in the corners
plastic sheet on the floor
Hottrucks is offline   Reply With Quote
Old 10-08-2009, 05:41 PM   #4
highperf4x4
Re: Storing A Truck
Drain the fuel
Make sure the coolant is full with proper antifreeze
Disconnect the battery
Put the truck up on stands
Let all but 15lbs or so out of the tires and smear some silicone on the sidewalls.
Hit your interior with something that will last a while like Meguiars.
Close it up tight and put a cover over it.
You may end up having to replace some items like the master cylinder, shocks, or anything with a rubber seal in it if this isn't stored in a "climate controlled" enviroment and any of these parts have some age on them. You will figure that out though after you start driving it again. You don't need to mess with the oil until you get back. I'd change it before you drive it though.
highperf4x4 is offline   Reply With Quote
Old 10-08-2009, 06:28 PM   #5
cdowns
cdowns's Avatar
Re: Storing A Truck
i'd put a really heavy coat of wax on the truck in addition to wats already been listed
Old 10-08-2009, 11:24 PM   #6
highperf4x4
Re: Storing A Truck
That's a good idea!
Old 10-08-2009, 06:43 PM   #7
mclairmo
Re: Storing A Truck
Hermetically seal it in a large plastic bag. Or, let someone you trust keep it until you get back on the condition that he or she drives it and maintains it.
mclairmo is offline   Reply With Quote
Old 10-08-2009, 06:57 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Storing A Truck
Dryer sheets or something like them.Even good storage places have a few rats/mice and you want to keep them out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-08-2009, 08:35 PM   #9
UltraBlue71
Re: Storing A Truck
Thanks all, as usual, terrific responses! I would have never thought of the steel wool or letting pressure off the valve springs.
mclairmo I'd loan out my only daughter before I'd loan out my truck for four years! J/K
71 LWB
Old 10-08-2009, 08:46 PM   #10
UltraBlue71
Re: Storing A Truck
71 LWB
Old 10-09-2009, 06:16 AM   #11
mclairmo
Re: Storing A Truck
Yeah, I feel the same about my 67 Camaro but my truck is a driver. I would not mind loaning my 68 C10 to someone I really trust, which happens to be only my dad.
Old 10-08-2009, 09:16 PM   #12
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: Storing A Truck
My neighbor tells me to spray WD40 down the intake with the truck revved up until it stalls. Helps prevent inner rust? Who knows if there is merit to it, but that was his suggestion.
texanidiot25 is offline   Reply With Quote
Old 10-08-2009, 11:20 PM   #13
highperf4x4
Re: Storing A Truck
Actually that's a bad idea. WD40 will scrub the cylinders and rings clean and makes them rust faster. You need to use a fogging oil if you're going to do it. You can pick some up at a boat shop.
Old 10-09-2009, 12:29 AM   #14
texanidiot25
Eat My Rust
Re: Storing A Truck
Damn old guy.
Old 10-09-2009, 12:31 AM   #15
highperf4x4
Re: Storing A Truck
Damn old guy.
hey, I'm just sayin.....................
Old 10-08-2009, 10:17 PM   #16
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Storing A Truck
The one suggestion that I think would be most important would be to drain the float bowls in the carb. That gas goes bad too. I would also grease all my suspension fittings before storing just for good measure.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-08-2009, 11:30 PM   #17
Average Joe
Average Joe's Avatar
Re: Storing A Truck
These are all great ideas. I'd never have thought of half of them. The only thing I would add is to make a list of everything that was done prior to your daparture and post in a very conspicuous place. Perhaps attatched to the steering wheel?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-09-2009, 12:47 PM   #18
UltraBlue71
Re: Storing A Truck
Good Call! Especially with my memory,
This is how it would have happened.....
Sometime in 2014-
hmmmm why wont this damn thing start (no batt, gas,)
Why does it smell like mothballs in here? (they are everwhere)
Whats that sticking out of the tailpipe? (steelwool)
Why does my motoer have so much valvetrain noise? (no oil)
Why wont my truck go (its on Jackstands)
Anyway you all are great, I really wanted to come back to ID after my year in Korea, but the Family really wanted to go see Europe before I retire, so UK it is, lots of board members from there, maybe I Ought to bring it along! instead of my Suburban, I wonder if they would let me haul kids in the back? Doubtful....
71 LWB
Old 10-08-2009, 11:26 PM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Storing A Truck
if you put it on jackstands, do it where the suspention is loaded, not unloaded.
I would do the synthetic oil BEFORE storage
tape or steel wool over the tail pipe AND over the snorkle on the air filter
leave antifreeze in it
moth balls on top of the engine, in the cab, under the truck on the floor, on the frame rails
if it has nace paint, cover the whole thing with a nice soft car cover, or moving blankets
Sta-bil will work for 4 years, seen it done myself. personally I would fill it up and put the sta bil in there, then dump it all out before starting. The fuel will displace the humidity in the air and prevent rust.
dont spray WD in the motor.
Old 10-08-2009, 11:32 PM   #20
highperf4x4
Re: Storing A Truck
Oh, one more thing. Take your wipers off.
If you're going to fill the tank and add the stabil then make sure you drive it around a little bit before you park it. Otherwise the fuel in the lines and carb will not be stabilized.
Old 10-09-2009, 01:25 PM   #21
Ackattack
Ackattack's Avatar
Re: Storing A Truck
Might want to see about some moisture absorbant stuff for the cab. Get it at an RV supply place.
Ackattack is offline   Reply With Quote
Old 10-09-2009, 01:27 PM   #22
67chevemall
67chevemall's Avatar
Re: Storing A Truck
Corona bottles in the tail pipes!
Keep the mice out
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-09-2009, 01:52 PM   #23
67sss
67sss's Avatar
Re: Storing A Truck
buy a bag of bbq bouquets, regular type, put any where you want no moisture, as they suck up moisture. Try em in your tool box to, if it's stored or used in a place where moisture is...and here in washington state we have a little moisture.
67sss is offline   Reply With Quote
