Old 10-08-2009, 07:26 PM   #1
rddaves54
rddaves54's Avatar
another problem
Problems one after another
I never put exhaust on because the paint guy (that did not finish the job on my truck) wanted me to leave them off. So I never heard the truck run except without pipes so that is why I have this question today.
I replaced my old exhaust manifold with new after market one and they have two holes in the middle (see picture) that I did not notice but they go all the way though. I had new exhaust put on today and they are leaking greatly. They do not go into my head so I need to plug them but I am not sure with what. Is this normal or what? I was wondering if they sell plugs for this type of problem or if a certain bolt is necessary with using lock tight would do.
One thing after another I wonder if I will ever get this truck on the road!
rddaves54 is offline   Reply With Quote
Old 10-08-2009, 07:45 PM   #2
vectorit
What?
vectorit's Avatar
Re: another problem
Those just look like smog port holes.
I plug em with flush pipe plugs that have an allen head.
I've never had to use locktite, just some anti seize and all was good.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-08-2009, 07:52 PM   #3
jay6891
Car Knocker
jay6891's Avatar
Re: another problem
x2
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 10-08-2009, 07:54 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
Re: another problem
Yep, agree completely. They're smog tube holes. Just run pipe plugs with anti-seize and you'll be good to go.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-08-2009, 07:58 PM   #5
mclairmo
Re: another problem
I would run pipe plugs, look nicer than other types of plugs and will fit flush.
mclairmo is offline   Reply With Quote
Old 10-09-2009, 08:59 AM   #6
rddaves54
rddaves54's Avatar
Re: another problem
do you know what size? Where is the best place to look for these?
Old 10-09-2009, 09:10 AM   #7
cdowns
cdowns's Avatar
Re: another problem
hardeware store// use ruler measure for size
Old 10-09-2009, 10:23 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Re: another problem
I think they take a 3/8" pipe plug.
LockDoc
Leon
Old 10-09-2009, 06:26 PM   #9
rddaves54
rddaves54's Avatar
Thumbs up Re: another problem
I got the plugs at my country Ace Hardware store and they are all plugged. I found out the holes are for the factory air emissions tubes. You would think they would plug them before the mail them out. Anyway I have it the manifold plugged and my new exhaust sound pretty good.
