Old 10-10-2009, 10:49 AM   #1
my67c20
What flywheel should i use?
I have a 383 stroker internally balanced that i am hooking up to a SM465 granny. Engine guy says i can run a standard 350 flywheel. Bought the clutch combo pack off LMC but still need a flywheel. Went out and counted the teeth and it has 185 teeth and is 14 1/8" in diameter. When i search all i find is 160 or 150ish tooth counts. What do i need? Will i need a starter to match? Thank
my67c20 is offline   Reply With Quote
Old 10-11-2009, 01:18 PM   #2
my67c20
Re: What flywheel should i use?
Anybody? Just want to make sure i don't buy the wrong thing
Old 10-11-2009, 06:19 PM   #3
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
My memory is a little fuzzy here since it's been a few years since I did my engine build but here is what I did. My truck had the original 11" or 12" flywheel, clutch and pressure plate. I also had a weak starter that I did not plan on reusing. In order to save some weight and make things safer I went back with a lightened '70 model Corvette flywheel. I bought a 10" clutch and pressure plate to match from Ram and installed a universal gear reduction drive starter. The flywheel was forged or whatever but the main thing being that it was designed for the higher revs of a modified engine and it must have weighed half of the stock flywheel so it should free up a few HP and be safer compared to the stock one. I think the flywheel was around 168 teeth but I could be off by a few either way. It took some time to get the starter shimmed just right but it works great.
I'll look back through my records and see if I can find something more definitive.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
