Rear frame supports on a SHORTWIDE BED???
I was looking at my Sons truck when we were putting the bed on. I noticed that it looked like someone had cutt off the supports that go on the rear of the bed and set on top of the frame rails. Here is my question. Are the frame rails the same for a Short Step as the Short Wide beds? I think once I get the bed wood in the truck and bolted together I will be able to build some brakets and weld them on just to support the back end of the bed to the frame rails. If anyone has some pictures of the underneath side of their Fleetside bed and how it attaches in the back it would be a great help. Thanks in advance.
JRBECK64 |
Re: Rear frame supports on a SHORTWIDE BED???
do you have any pics of what your dealing with? the way im understanding it is someone cut up the rear cross sill is that correct? if so Mar-k has them for 125.00 you can look at their web site and see a picture of what its supposed to look like. hope this helps.
Member of the longbed union.
he's talking about the bed mounts. I think they are the same but dont quote me. Jason at SD makes some that bold in www.***************** But they are easy to make.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Here is a couple of pictures of the back of the bed so it will make my problem a little more clear. Unless the picture taker was shaking when he was taking the photos.
I believe that the rear frame of the 60 to 62 were wider so looks like that rear cross seal is from an earlier model but as 47 guy says you can get a correct replacement with the right tabs that will mount to the frame from mar-k or lmc trucks
well I guess I was wrong, Yeah i would hit up Mar-K, MGBMike, or classic enterprise.
Here are a couple photos that miht help. They are of my 65 SWB Step.
The remnants of the brackets on your cross sill looks like the same mounts. I ended up welding my brackets to the rear frame rail because they were stress cracked and breaking away. From the factory they are made from sheet metal, a small boxed sub-assembly. On my Short-Step the mounts line right up with the rear frame rails. The pictures don't show this because I shortend the frame rails to allow clearance for a rear roll pan. Unless you are going for a restoration quality appearance you could make your own brackets out of some structural steel angle or square tube. Like I said previously, the factory mount is pretty wimpy and prone to cracking. Hope these help. Last edited by lakeroadster; 10-11-2009 at 07:29 AM. |
Thats a nice looking tank, whats it out of? If you dont mind me asking.
#9 | |
. It's a '49-'52 Chevy passenger car gas tank. My build thread, listed below in my signature line, has more details.If you have any questions just post'em up. Last edited by lakeroadster; 10-11-2009 at 04:46 PM. |
#10 | |
JRBECK64 |
'60-'62 frame rails are the same width, regardless of stepside or fleetside beds, the same is true for '63-'66. The earlier frame rails are farther apart than the later years. It appears your bed, or at least the rear cross sill, was a '60-'62 and the frame is a '63-'66, therefore the rear cross sill frame perches were cut off, as evidence by the flanges still on the inner face of the rear cross sill.
I have seen a 2" x 2" square tube, approximately 4" long welded at the end to the inner face of the rear cross sill, to suffice for the rear cross sill frame perches. Also, you can drill the spot welds on a pair of factory rear cross sill frame rail perches and install them on your rear cross sill in the proper location. Hopefully this information is helpful. |
#12 | |
Thanks again for the info. I kind of lucked out today as I noticed the pads on the crossmembers were not lining up on the bed. I recently purchased some used crossmembers and they are the correct ones. My Son wire brushed them and painted them with POR15 today. Now all we have to do is remove the crossmembers that are currently on the bed and replace them with the new ones. JRBECK64 |
| Bookmarks |
