454 Exhaust Suggestions Needed
What is everyone running exhaust wise for their 454's? I am almost to the point that I will be ready to fire up the truck after replacing head gaskets but I need to figure out exhaust before I can.
Right now the setup on the truck is as follows: Dual exhaust, 2.5" pipe out of headers all the way back to glasspacks (look like old rusted cherrybombs) that dump under the bed before the rear axle. The truck is LOUD, even in the cab. Highway driving is uncomfortable for extended periods of time. I was looking for info on how these were run from the factory and found conflicting info. Seems some came with dual exhausts, some with y's with a single exit. Should I stick with the dual exhaust and just swap out for dual mufflers and extend the pipe out the back? How will a Cat' factor into all of this? Due to it being an 83 I do not have to be emission tested in Texas but I believe I still may have to pass the "visual" inspection. I obviously do not want to restrict the flow and cause issues but I also do not want an obnoxiously loud truck. Would prefer a subtle, deep, v8 rumble that sounds good but allows me to keep my hearing! ![]() Last edited by cLaWz; 10-11-2009 at 01:46 PM. |
78 Big10 454
![]() Join Date: Jul 2008
Re: 454 Exhaust Suggestions Needed
My Big 10 454 came with factory dual exhaust. The set-up consisted of 2.5 inch pipes off the exhaust manifolds wyed to a single Cat mounted on the passenger side that wyed off into two pipes and two mufflers. The exhaust pipes dumped behind the rear wheels. I swapped out the stock exhaust manifolds for a pair of CARB-approved Hedman headers. From there, I ran each exhaust pipe through its own Cat and muffler straight out to the rear. Still a bit too noisy for me with glasspacks. Although I have to have the truck's emissions tested every two years, I've never had a problem passing either the visual or performance part of the test. Hope this helps.
![]() Join Date: Apr 2009
funny you should bring this up.... i am in the process of re-doing mine. i just bought Summit Racing race mufflers (flowmasters knockoff) in 2 1/4".
My exhaust man says 454s need some back pressure, so he suggested 2 1/4. i ordered them today. he will do it as soon as they come in. my truck is a regular gas/no cat w/factory dual mufflers now. we'll install the Summits and new pipe from exhaust manifolds back and straight out the back. 2 1/4 all the way
1981 Chevy C30 440 Holmes 42K one owner miles |
Ive got flowtech long tube headers and 2.5 that dump just before the rear, the only difference is I have flow's. Its still really loud but a little quieter than glass packs....If you take it all the way out the back it will be better plus you dont want to put a cat on if you dont have to
77 Scottsdale,.454 .30 over, 10:1 flat top pistons, 480 lift comp cam, 781 heads stock valve size, some no name polished aluminumn dual plane intake advised by my machine shop to match the cam(He said is was great lol) Holley 750 vac sec, Turbo 400 built raybestos clutches and Kolene steels, Eaton Posi 3:73 14 bolt ![]() |
#5 | ||
On the Cat issue I'm not entirely sure if it is going to be needed or not. Text from the emissions laws here in Texas.
Thanks for the suggestions on everything else. The goal for my "fix it" build is to turn it into a daily driver and the exhaust is an issue with that. The drone these glasspacks have just really gets to me at highway speeds and is so loud it even drowns out the stereo and wind noise. I've never run open headers but they can't be much louder then this current setup. ![]() Would an eventual dual system with a crossover pipe (H or X.. dunno yet, still learning this stuff!) in 2.5 work well for a 454 but still be a good setup for an eventual 350? And one other random question, anyone know where to pick up some plugs for the emissions tubes out of the headers? The pipework was falling apart when I tore down the motor to replace the headgaskets. Last edited by cLaWz; 10-11-2009 at 04:52 PM. |
Old Heap Driver
I just completed a 454 swap in my truck. Stock manifolds, 2 1/2" pipe, 3" Magnaflows, 2 1/2" pipe over the axle and straight out the back. True duals.
The Magnaflows sound way better with the 454 than they did on my 383 powered S-10.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Hooker headers to 2.5 true duals with no cats and 40 series flowmasters with turn downs
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
How loud is that setup if you don't mind me asking? Running what I believe to be stock headers but sounds essentially like what I'm going to end up with shortly.
I'm on the process of doing mine also. I am planning on hooker long tube headers with 2.5 piping to some mufflers which I Dnt know which to get
1973 custom delux 20 with 454 project 2000 dodge neon |
It's not bad for driving. Dont get me wrong but you can still tell it is a big block.
No No
I have full length headers with a 2.5 dual system with glasspacks with H pipe. Now I had to cut the pipe infront of the axle when I installed the hitch. I had the exh straight out the back. Before the chop it was very quiet in the cab but sounded great to everyone else in the world. I keep saying Im going to fix it back to the way it was but just havent found time and the snow on the ground and the buick in car hole kinda prevent me from doing anything.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
Claws I might as well be in Austin also and I just had mine inspected one month ago in travis county and they didnt give me a single bit of grief about the cats. It might also depend on where you take it, two different shops might do two different things.
I believe 84 and up requires visual inspection.
Sounds like you have a good setup. 2.5 is good size for a big block and over the axle and out the rear is best for directing the noise away from you, it just sounds like you need some different mufflers. I would suggest swapping in a pair of turbo mufflers, or a pair of Flowmaster 50 series Delta Flow. I would also suggest adding a crossover pipe to help overall flow and scavenging, but mostly for fact that they take the edge off the exhaust note.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 10-13-2009 at 07:00 PM. |
i have doug's long tube headers into a 2.5 inch pipe with no cats into flowmaster 50 series mufflers its very nice driving it around theres no drone but the exhaust is a little small i would go 3inch. when i redo mine it's going to get a 3 inch.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#15 | |
![]() Sounds like Turbo mufflers and out the back is the way to go then with maybe a crossover pipe later. thanks all |
#16 | |
#17 |
Still plays with trucks
The pipe size depends upon how your engine is built.
If it is pretty much bone stock a 2-1/4" dual system will work best. If it has headers, a mild cam and an aftermarket dual plane intake dual 2-1/2's will work better. If it has a big cam, single plane intake, big valve heads and higher compression a dual 3" system is the way to go. If it has a nasty cam, rectangular port heads, very high compression and large tube headers then a dual 3-1/2" system will work. Going too big for your combination will lose power and efficiency just as bad as going too small. Most street driven trucks with typical modifications will work great with a dual 2-1/2" system. I ran 1-3/4" primary long tube headers reduced to 2-1/2" pipe into an X-pipe, Flowmaster 50 series SUV mufflers and Flowmaster mandrel bent tail pipes on my 67 C-10 with a 427 and it worked great, sounded fantastic and wasn't overly loud at idle. It was still plenty loud when you got on it though. I am in the process of putting the same system onto my 78 K-20 but may not run the X-pipe for ground clearance reasons. |
#18 | |
1983 C20 - "Project Do It Myself" Last edited by cLaWz; 10-14-2009 at 08:56 PM. |
#19 | |
#20 |
open headers
#21 |
My 73 has LT headers, to a stainless Xpipe w/cut outs, to Flowmasters w/3" pipe to 4" chrome angled tips that dumps right over the rear end
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
#22 |
I run a set of hooker supercomp long tubes back to a 3.5" collecter into 3" pipe to a set of flowmaster 40's to a 3" turn down over the rear axle. Works great for me....but everything i own is neighborhood-window-rattling loud!
The Devil ![]() 1983 ONE TON 454/400/208 11" of lift on 44's |
#23 |
get some larger series spintech mufflers great sound control at idle and crusing but when you stomp it it sounds really nice
#24 |
i was about too post this exact question? my 454 has 3in from the headers back with original 40s the whole exhaust came out of my blazer. the muffler is right under the cab with about a foot of pipe after that. way to loud. sounds like 2.5 is what most people have
#25 |
Anyone have any tips on sources for exhaust pipe sections longer then 18 inches? Called the muffler shops around me and they say they don't sell it on the side, they have to do the install, etc. Autozone, Advance, and Oreilly are all showing their "on hand" sections of straight pipe at 18 inches or so.
Being new to most of this stuff.. can I pick up some non coated steel pipe at like Home Depot or something and use that? I just need 2 straight sections to connect up with new mufflers and extend to the rear bumper. Just a patch job for right now until I build a new system with from headers back. On another note, where is the best location to put the muffler to cut down on the noise level in the cab? Closer to the rear bumper or as close to the manifolds as possible?
1983 C20 - "Project Do It Myself" Last edited by cLaWz; 10-26-2009 at 09:39 PM. |
