10-11-2009, 02:38 PM | #1 |
Restoring a 68 SWB
Need advice on Motor Purchase
I found an early 90's (not sure what year) 350 for really cheap. Not that interested in the motor, but the guy says it has all the pulleys brackets, ac pump, alternator, etc..
I am mainly interested in the Serpentine Setup off of it. I was told last night that early 90's wouldn't work, but I wanted to double check here and make sure.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 10-11-2009 at 02:39 PM. |
10-11-2009, 03:46 PM | #2 |
Hollister Road Co.
Re: Need advice on Motor Purchase
I have a 91 on mine. I did have to use the pressure valve from the old pump so it would mate up to the stock hose. Also remember that its a reverse rotaion water pump so if you replce it you need to get one from that newer year. If your not using the A/C pump you can get an A/C delete pulley.
10-11-2009, 05:20 PM | #3 |
Just Not Low Enough!
also you need to make sure you have the accessory holes in the heads to accommodate the serpentine setup.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
10-11-2009, 10:44 PM | #4 |
Restoring a 68 SWB
I doubt the heads on my 307 have those holes. Gonna swap to some 305 vortec heads this winter so I might just wait until then to put the serp setup on. Thanks for the info guys.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
10-12-2009, 09:34 PM | #5 | |
Hey Dave, You're my dad!!! Just kidding but my dads name is David Chapman alot of people call him Dave.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
10-13-2009, 12:35 PM | #6 |
Restoring a 68 SWB
My name is really Trai. Davenport is my last name, so I just used the first initial of my first name and the first four of my last name - TDave.
10-12-2009, 08:21 AM | #7 |
Watch out for your cornhole !
Your 307 should have the holes.
10-12-2009, 09:03 AM | #8 |
Under Construction
Dave,
there is some good reading on Serp belts in the below thread. I ended up going with a serp. setup off of a '94 burb, it bolted up fine (pics in the '67 build ). http://67-72chevytrucks.com/vboard/s...d.php?t=233335
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-12-2009 at 09:03 AM. |
10-12-2009, 09:26 PM | #9 | |
Restoring a 68 SWB
Guess all there is left to do is go pick this motor up. $125 for the motor and all the serp brackets, ac pump, etc... He says it has good oil pressure.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 10-12-2009 at 09:28 PM. |
