10-11-2009, 05:45 PM | #1 |
Dome Light Switch in door ?
Hello everyone, I brought home a cab to replace the one on my truck yesterday, and upon checking it out closer I noticed is doesn't have any holes in the the door frame for a dome light switch on either side. I've never seen a cab without the switches and am wondering if someone may have welded them up. Has anyone else every seen a cab missing these hole from the factory?
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
10-11-2009, 05:48 PM | #2 |
Re: Dome Light Switch in door ?
Here's a photo of the door opening
10-11-2009, 06:28 PM | #3 |
Parts and more parts
Nope, there were trucks without the switches mounted. I put the switches on my 72 truck when I had it, so it can be done easily. All you are creating with the switch is the ground circuit, so it is not hard. the switch goes on the flat part that is stick out slightly in the middle of the frame.
Frank |
10-11-2009, 08:39 PM | #4 | |
The Red Menace
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
10-11-2009, 08:06 PM | #5 |
Thinks for the reply, Yes, I will be adding them to this cab as well.
10-11-2009, 09:01 PM | #6 |
70 Chevrolet=Obsession
I'm pretty sure that all stepsides came without door switches unless optioned for them. Mine sure doesn't have any and I don't care.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
10-11-2009, 11:07 PM | #7 |
its all about the +6 inches
all the trucks came without them unless optioned otherwise, it was an option on all 10 - 30 C or K trucks. It was not avalible at all before '69.
Before someone says "its not listed on my SPID... It was part of some option packages... but, that is an optional package, as in not base equipment. Last edited by Longhorn Man; 10-11-2009 at 11:08 PM. |
10-20-2009, 09:39 AM | #8 |
I appreciate the info, I'll probally be drilling the holes and tapping them to accept the switches.
10-20-2009, 04:57 PM | #9 |
I believe the switches will "Self-tap" themselves into the sheetmetal.
Frank |
01-08-2010, 12:06 AM | #10 |
Chevy Lover Till The End.
Hello fellers, could someone post a picture on where to mount the switch, my truck doesn't have them either and I don't understand exactly where they are mounted if they were ordered from the factory. Thank you
01-08-2010, 11:12 AM | #11 |
I don't have pictures of my old cab, but this might help.
01-08-2010, 12:45 PM | #12 |
Middle-aged Curmudgeon
Yeah, they sort of do. I had to replace one on my '72 and it fit somewhat looser than the old one did. Wouldn't really tighten up. I left it be for now and it works, even being a little sloppy in the hole. When I restore I'll weld that hole up and re-drill it.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
01-08-2010, 08:52 PM | #13 |
Thanks a lot. Helped me greatly.
