10-13-2009, 05:23 PM | #1 |
Between Trucks...
A/C Cab Question
Is the air flap under the cowl, made of steel on an A/C cab? Got a small leak in my cab and pretty sure that's where the water's coming from, I'd like to weld it shut.
Beat it to fit, Paint it to match... Last edited by Sinister; 10-13-2009 at 05:24 PM. |
10-13-2009, 05:46 PM | #2 |
Re: A/C Cab Question
air flap under the cowl? do you mean the air vents on the sides? unless an A/C cab is totally different than non A/C i'm not picturing the area that you are talking about.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-13-2009 at 05:46 PM. |
10-13-2009, 05:56 PM | #3 |
Between Trucks...
There is an air flap under the cowl on the passenger's side, pretty sure it's vacuum operated. I can't remember if it's steel or not. If you pull the cowl you can see it on an A/C cab.
Beat it to fit, Paint it to match... Last edited by Sinister; 10-13-2009 at 05:57 PM. |
10-13-2009, 06:28 PM | #4 |
Ah yes, the first rain in Los Angeles in... what? 10 months? literally! Great time to start finding new leaks, and other foul weather related problems. Good luck sealing it up!
10-13-2009, 06:35 PM | #5 |
Between Trucks...
I've been waiting for this for a while, to see if shaving my firewall cured the leak. No such luck, but I did finally find the leak, or at least I think I did.
Beat it to fit, Paint it to match... |
10-13-2009, 06:46 PM | #6 |
The one on my 72 is a composite or plastic. Not metal.
Well I was going to post a pic for you but it's not giving me that option for some reason.... |
10-13-2009, 06:51 PM | #7 |
Between Trucks...
Thanks dude. Well, looks like I have some work to do this weekend.
10-13-2009, 06:56 PM | #8 |
most cab leaks are from dried out drip rail caulking
10-13-2009, 07:02 PM | #9 |
Between Trucks...
Thanks cdowns, but I think I've got it nailed now. It's leaking from under the airflap in the cowl.
10-13-2009, 07:05 PM | #10 |
The fresh air intake (flap) does have a rubber seal around it that might be bad. You may try replacing it before just welding it up. The "flap" comes out real easy.
No attachments while migrating to the new site server is what I read so it looks like I won't be getting that pic to you anytime soon. |
10-13-2009, 07:02 PM | #11 |
10-13-2009, 07:46 PM | #12 |
Between Trucks...
I'm like 99% sure the Vintage Air Surefit kit doesn't need it. They have the installation instructions available for download.
10-13-2009, 10:49 PM | #13 |
good info... thanks.
try photobucket for easier pic posting... upload your pics and then copy the IMG link to your text...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-14-2009, 04:43 PM | #14 |
Spanked once
The AC vent you speak of would only leak into the fresh air plenum and what ever water there is should drain out the hole in the bottom of the plenum behind your kick panel vent unless it is clogged. The only hole I saw on my stripped cab today was in the top right corner for the antenna.
Mine is an AC cab. HTH
The ole 350 budget build. |
10-14-2009, 04:49 PM | #15 | |
Between Trucks...
10-14-2009, 05:07 PM | #16 |
Spanked once
Give me a minute ... ah here it is
http://67-72chevytrucks.com/vboard/s...d.php?t=253241 In the bottom left there is hole big enough to get your finger in or a mouse.
10-14-2009, 05:12 PM | #17 |
Between Trucks...
Thanks for the pic.
Mine is actually leaking towards the top by the cowl. Pretty sure water is coming in at the air flap and sitting in there.
Beat it to fit, Paint it to match... Last edited by Sinister; 10-14-2009 at 05:12 PM. |
10-14-2009, 05:28 PM | #18 | |
Spanked once
You don't wanna here this probably but in the front the windshield 0n each side I welded all that in rather than using caulk liked they did years ago. Oh , and the top also.
10-14-2009, 05:34 PM | #19 |
Between Trucks...
Any pics of where you welded? I'm pretty sure it's not the windshield. I went out there while it was raining and it's leaking right behind where the glovebox would go in the corner. This leak is driving me nuts.
10-14-2009, 06:04 PM | #20 |
Spanked once
As it should ,I will take em tomorrow in and out but I think it is your windshield area. Try this.. use masking tape and seal it off and use a water hose on it for a while. If that ain't it then do the cowl area.
The ole 350 budget build. Last edited by Richard H.; 10-14-2009 at 06:07 PM. Reason: n/m |
10-14-2009, 06:15 PM | #21 |
Between Trucks...
Here's a pic of where it's leaking. Under the windshield is dry.
10-14-2009, 06:43 PM | #22 |
I'm not sure if that's under the fresh air intake or just beyond it but it's right in that area. that black plastic nut in your picture is the back side of the flap latch. I think I would take the flap out and just look and feel around and see what it looks like. You have to take out three 5/16" screws (just two if your A/C box is not on the firewall) and a spring loaded catch to get the flap out. My cab is at the blaster so I can't look at it for you or I would.
10-14-2009, 06:46 PM | #23 |
Between Trucks...
I think it's just to the right of the air flap. I'm going to see what's up with it this weekend. Thanks for the help guys.
10-14-2009, 10:58 PM | #24 |
I really hate wet sanding!
In your pic that shows the leaking area, I would pull away the cab insulation for a closer look. I think you will find the leak is where two panels meet, I have two cabs that have the same leak. This seam was spot welded at the factory as the cab was built, the they smeared a bunch of seam sealer on it waterproof the seam. On my affected cab, it appears that area held water over the years and eventually rusted through. The worst one I have (basically junk due to this and other areas of rust) has about a 2" x 1/2" hole rusted along this seam. Sorry if this is the case, because it will be a huge PITA to repair.
