Old 10-14-2009, 06:13 PM   #1
67chevylongbed
67chevylongbed's Avatar
67 C10 327 PCV Question
The truck was originally an Oregon truck so I don't think there would have been a PCV system on it originally. There is however a hose running from the back of the intake manifold and laying on the inner fender with exhaust coming out. Where is this supposed to be connected to, or can someone just show me how to hook the PCV up properly. It has an aftermarket 600CFM Holley 4 barrel electric choke carb.
The valve covers have no oil ports. The oil port is in front of the intake manifold.
Thanks ahead of time if anyone can help me out.
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 10-14-2009, 06:16 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: 67 C10 327 PCV Question
does the truck have power brakes? are they aftermarket valve covers or orginal?
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 10-14-2009, 06:23 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Does it have an auto transmission?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-14-2009, 06:37 PM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
a picture may be able to answer a few more questions about the problem.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 10-14-2009, 06:59 PM   #5
RW71
RW71's Avatar
That is a Road Draft tube.
RW71 is offline   Reply With Quote
Old 10-14-2009, 07:47 PM   #6
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
I have a 67 C20 that is original to oregon with a 327. It has no provisions in the valve covers, there is however a tube that comes up from the rear of the block with a PCV valve inline. The other end connects to the base of the carb as usual.
screamin_c10 is offline   Reply With Quote
Old 10-14-2009, 07:57 PM   #7
screamin_c10
So we cant post pics at the moment...but if you look at this thread second pic you will see where the PCV valve goes. That would be the large hose just behind the carb carb mounting surface. My truck is about as factory original and unmolested as you can get around here, so I have no doubt it is the original setup. Hope this helps....
Old 10-14-2009, 08:47 PM   #8
67chevylongbed
Thank you for the help.
They are manual drum brakes, so no vacuum is being used from the intake manifold for the power booster. It is a manual transmission, stock valve covers. Sorry I can't take a pic at the moment.
Eric
-Ronald Reagan
