Old 10-15-2009, 06:42 PM   #1
1great68
Timing question I think ?
When I turn my truck off it tries to start back up. Is this a timming problem or something else?
1great68 is offline   Reply With Quote
Old 10-15-2009, 08:01 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Timming question I think ?
Sounds like your timing is too far advanced. Did it just start doing this or has it been going on for a while?
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 10-15-2009, 08:32 PM   #3
LiveAnimals
LiveAnimals's Avatar
Same thing happened to me, my started soleniod stuck. Wouldn't stop cranking until the battery died. If it is continuously trying to start itself until the battery dies, I would say its the same prob I had. If it cranks once then dies or twice I would agree about the timing issue.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 10-15-2009, 08:58 PM   #4
cowboy5683
Sounds to me like yer describing a situation like after you have driven for awhile then you pull up in yer driveway and shut the key off but the motor continues to run but like crap for a lil while..If that is what is happening it is called "dieseling" or engine run on..many different reasons for run on..I would check all the basics first..timing, idle, airfuel, carburetor adjustments(throttle linkage closing all the way) etc....Then check cap, rotor, wires, plugs and replace as necessary..Basically a tune up if needed..Afetr all the checking you will prolly find the culprit.
cowboy5683 is offline   Reply With Quote
Old 10-16-2009, 04:32 PM   #5
LiveAnimals
Re: Timing question I think ?
Cowboy's the man
Kameron
Old 10-16-2009, 07:33 PM   #6
GMC Guy
GMC Guy's Avatar
Originally Posted by LiveAnimals View Post
Cowboy's the man
x2
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 10-15-2009, 08:51 PM   #7
jholley
jholley's Avatar
Are you meaning to say that when you shut your truck off it seem to continue to run? If so you need to check your timing. It's too far advanced like 85GMCGuy said. If you are saying that when you turn your key to the off position the starter engages then you have an ignition switch problem my friend.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 10-15-2009, 08:54 PM   #8
1great68
When i turn it off it continues to run. I thought it was the timming, i will back it off a little thanks for the help.
