ISO/WTB '60-'66 GMC 305 V6 alternator brackets
In Search Of/Want To Buy top & bottom alternator brackets for '60-'66 GMC 305 V6.
1961 crewcab
Re: ISO/WTB '60-'66 GMC 305 V6 alternator brackets
tony, I might have some, my gmc 4000 has a 351, and the alt is on the right side, I will try to get a pic for you to see if they look like the right one...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#3 | |
I need to wire it, once I get it mounted. There are three wires to hook up. The wires are Blue, Black & Red. Any suggestions? |
On my 351,there are only 3 pieces for the alternator mount.
The top adjusting bar and 2 parts that fit together to hold the bottom. They are the same as a 305's mounts. If you can't find them,you could probably make the bottom parts. Mike. |
I have the brackets you need Tony, but they are about an hour away......
what are they worth to you?
An hour...are you still in Norman, OK?
I ended up installing the factory generator and mount, but I want to go with a modern alternator and brackets. |
Yeah I'm in Norman still
I meant the brackets are a hour from me..... But now that you mention it, they might be generator brackets...
I found the factory generator and brackets, so I installed them and hooked it up like this:
1961 crewcab
tony, I forgot my camera, but my upper bracket is the same as you have, however the lower is huge, the fenderwell is actually notched our from the factory to make room for it, I assume the bracket has provisions for an air pump that might not have been used on my truck. I will still try to get some pics for you, but I don't know if mine will work on your 1/2 ton...
![]() Join Date: May 2007
I have seen generator converted to a 12v alternator on street rods.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
If you want to see a picture of mine,it's on my picturetrail site below.
The album is the one with the pic of my 68 truck.The engine is sitting on the floor in pic 30.Not a good picture,but shows the alternator mounted.There may be other pictures of it in there too. Mike. ![]() ![]() |
Thanks for the information. I got it mounted and wired using the factory mounting brackets and harness. Tim Gehring is the proud new owner.
![]() Join Date: Nov 2007
Very proud owner!
