Old 10-16-2009, 09:52 AM   #1
Sinister
Between Trucks...
Sinister's Avatar
Fuel Tank Sending Unit
Motor I'm looking at would require an electric fuel pump. I would probably need to rig up a return line to the tank in my '69. Does a '72 fuel sending unit have a place for the return? Would it fit my '69 gas tank? Or should I just run the electric pump dead headed into the regulator and forget running a return line?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-16-2009, 10:56 AM   #2
Mertz
Re: Fuel Tank Sending Unit
I just replaced mine in my 72 and I believe it had a second line. I'm not sure but I think it is the vent. You can see a picture of the part in the LMC catalog.
Mertz is offline   Reply With Quote
Old 10-16-2009, 12:30 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Thanks for the reply. I think it's a return and the vent is on the fuel tank neck IIRC. Just wondering if a '72 sender will fit a '69 tank.
Beat it to fit,
Old 10-16-2009, 07:23 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
The sending units will interchange between years.
LockDoc
Leon
Old 10-16-2009, 06:55 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Bumpity Bump.
Beat it to fit,
Old 10-16-2009, 07:15 PM   #6
wildwilly4x4
X2 on the question, I'm putting a 6.5 diesel in my rig and I also need to know which sending unit to get.
wildwilly4x4 is offline   Reply With Quote
Old 10-16-2009, 07:26 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Cool, thanks. Is the second line on a '72 sender a return?
Beat it to fit,
Old 10-16-2009, 08:26 PM   #8
LockDoc
LockDoc's Avatar
I don't think so, I think it goes to the vapor canister. I don't know why it couldn't be used as one though.
LockDoc
Leon
Old 10-16-2009, 09:37 PM   #9
Jayss109
Active Member
Jayss109's Avatar
there is a return on a 72 sender. Works fine on my cad fuel pump.
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 11-25-2009, 10:39 PM   #10
tomtuna1978
has anyone put an in tank electric pump in the stock tank,with the stock sending unit ? im thinking of doing this for my 69 big block. im converting it to e85 and need to either put a pump in the stock tank, or do one of those aftermarket tanks under the bed.
tomtuna1978 is offline   Reply With Quote
