Enjoy your truck
Gas gauge needle flutter
I don't know if this is a unique problem or not, but I did search through other threads and couldn't find a situation similar to mine.
In my '63, I installed a 21 gallon replacement gas tank under the bed. I used the sending unit that came with the tank, and it functions well - to a point. The gas gauge reads accurately in respect to my fuel level. My problem is that the needles flutters VERY rapidly at random times. I just changed out the stock gauge with another stock gauge. The flutter is still there, just not as severe. I know the signal from the sending unit is getting to the gauge, but I have no idea why the needle flutters. Can anyone shed some light on this? Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
Enjoy your truck
Re: Gas gauge needle flutter
I have also noticed that the gauge is normal (no flutter) when they key is on and the engine is not running.
Also, it is most noticeable at 1800 - 2000 rpm. At idle it seldom flutters, and above 2500 rpm it seems to be normal. Is it possible that there is something in the alternator or tachometer that is interfering with the gauge? Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee Last edited by Greg63; 10-17-2009 at 05:54 PM. |
First thing I always check with any electrical glitch is the ground wire.
Run a temporary ground to a good source and see if the problem changes. Last edited by lakeroadster; 10-17-2009 at 05:58 PM. |
Enjoy your truck
Thanks for that tip, but I have done that, too.
I had the tank out of the truck two weeks ago to check the sending unit - which seems to be fine. At that time, I verified the ground from the tank, and today I checked the ground at the dash wiring harness. Greg
SSN 706
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold)![]() Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it"
haha my 63 does that too and today i ran outta gas! how embarassing huh? not to hijack but mine reads off some times and its killin me
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield ![]() .......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS..... ![]()
SSN 706
I think we all need to fork out the 50 and get new sending units. na
haha no $h!t huh lol
SSN 706
Ya that would be to easy. Just pull it out a few more times and bend it some more.
Here's a couple more idea:
A) You mentioned you installed a replacement tank. Your 1963 gas gauge needs a 30 ohm sending unit. Is the sending unit a 30 ohm or a 90 ohm? B) I had a similar problem with the Tachometer needle in my '69 Camaro and I put a 10K, 1/2 watt resistor in the line and it calmed down the erratic readings. I don't know if this will help but I do know ithe resistor was only a couple bucks @ Radio Shack. Might be worth a try? Last edited by lakeroadster; 10-18-2009 at 08:01 AM. |
#11 | |
Enjoy your truck
I can only assume the sending unit is the correct 30 ohm piece. The needle actually reads properly and is accurately showing the true fuel level, it just decides to flutter from "F" to far right and back again. I was thinking about adding a resistor, but had no idea where to start in respect to which one to use. I already have some from another project that I can try out. I will put one in and see what I get. Greg.
Enjoy your truck
Well. I just tried various resistors, from 1k - 4.7k, and all they did was bury the gas gauge needle to the right of "F".
I also tried disconnecting the signal wire from the tach - no change. Any other ideas out there? Greg.
#13 | |
Then again my gauge does basically the same thing and it's all stock so this may have nothing to do with it.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
Here is my guess....
Does the new tank have baffles? The reading is correct when there is little to no vibration. When the truck hits the right range the gas vibrates and creates little waves in the tank. This would cause the needle to wave. Just a thought. |
#15 |
Enjoy your truck
It has no baffles in it. I wondered the same thing.
I was trying to eliminate all other sources before I settled on that as the source of my problem. Thanks. Greg.
| Bookmarks |
