Old 10-20-2009, 04:51 PM   #1
KD70chev
rear axle options for c20 coil
I have my grandfathers 70 C20 manual truck and would like to change the rear end or gears as I have the 4.56 gears and it just screams going 70 down the highway.I would like make it more of a daily driver.I think i remember someone saying I could get an older dana 60 from a 3/4 ton dodge is that right?If I only went down to 410 would that be enough of a difference or do I need to get it down around 373, 350 small block motor.Has anyone had the ring and pinion changed and is that a cheaper way to go?It would be nice to actually use first gear and feel more comfortable going on longer trips.Thanx KD
KD70chev is offline   Reply With Quote
Old 10-20-2009, 10:28 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: rear axle options for c20 coil
A 4.10 swap would a great move, but a dana out of a big block 68 - 72 would be a 3.54 and be a huge impovement.
Old 10-20-2009, 10:38 PM   #3
into69z
"brand new second-hand"
into69z's Avatar
I put a 1986 3/4 3.23 in my 69 c20 and it really makes a difference. I bought brackets and a new panhard bar from cpp and had a shop weld it up. I searched for gears and found they do not exsist and the bearing and seals are hard to come by....thats for the stock 3/4 69 drop out rearend...
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 10-20-2009, 11:17 PM   #4
Longhorn Man
by drop out rear end he means Eaton, or coperate.
Old 10-21-2009, 10:51 AM   #5
KD70chev
Thanx Guys I will do some calling.KD
