10-20-2009, 11:45 PM | #1 |
lift kit
where can i find mild front end lift kit for a 1986 C20 Scottsdale 2wd. I cant find anything for a 3/4 ton. Im just looking for street just a little something prefferably just a spindle lift. It already has the HD springs in front with 33x10.5x16.5 BFGoodrich mud terrains all around but i just want something to get a little more clearance but i do haul with it so it still needs the ridgidity. Please help
10-21-2009, 01:42 AM | #2 |
Re: lift kit
baja spindles or bbc springs.
10-21-2009, 06:04 PM | #3 |
Re: lift kit
I do not believe there are spindle lifts currently available for 73-87s. You could add a coil spring spacer but eventually you will make out when the upper arm hits the coil spring bucket and your ball joints are maxed out.
A spindle lift would your best option... and you might be able to swap a 88-98 spindle over. I just don't know how compatible it would be with a 3/4 ton hub.. if there is even a difference in the bearings/races with a 1/2ton (88-98).
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
10-22-2009, 04:49 AM | #4 |
Re: lift kit
I've got a an 1.5" lift spring and a balljoint spacer on my 78 c20. I believe the only company that makes lift kits is AIM.
coil/balljoint-spacer&Coil/upper arm &coil/extended uppers and lowers |
10-22-2009, 11:35 AM | #5 |
6.0 powered square
Re: lift kit
I did hd coils and a 3" body lift on this truck it has 235/85/16 32" tall
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-22-2009 at 11:36 AM. |
10-22-2009, 04:33 PM | #6 |
Jonny
Re: lift kit
I currently have 3" lift coils on my truck. I found mine in a 3/4 ton that I parted out. I ordered ball joint spacers from airbagit.com a couple days ago. they were under $50 shipped
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
