01-18-2003, 01:16 PM | #1 |
Anyone know antyhing about limited slip?
I am looking for information on rebuilding the limited slip in my 85 chevy truck. It has an axle code of KXA wich is a "3.07 locking" differential. The limited slip part is not working as good as it used to and I am wanting to replace the clutches in the rear end.
Any help or information would be greatly appreciated. Thanks, Mike |
01-18-2003, 01:37 PM | #2 |
Garage Queen Material
to tell you the truth, i'm not sure if the stock ones are rebuildable.
01-18-2003, 04:05 PM | #3 |
I'm with Ocbaud....I don't recall them being rebuildable......i've heard good things about a Detriot locker and also Eaton has good posi's...either are pricey tho.....but from what i understand...the detroit locker doesn't wear out because the teeth lock....no clutches to burn up......anyone correct me if i'm wrong.
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
01-18-2003, 06:31 PM | #4 |
yeah, eaton's are rebuildable. thats the kind i'm gonna be getting
01-18-2003, 07:40 PM | #5 |
yeller
Some are rebuildable, I asked this question to a local driveline shop quite some time ago...but I can't remember the specifics...
I THINK it depended if they had steel or aluminum plates or something like that. I know this doesn't help much...but I do know "NO" is not the completely right answer. -Jeff |
01-19-2003, 05:48 AM | #6 |
Workaholic
Go with a detroit and never look back.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
