10-23-2009, 02:13 PM | #1 |
Drop Member question
Ok I know acouple of yal have Drop Members from Porterbuilt...My question is how much do they run? I called and talked to the guy there acouple of months ago and can't remember or find my sheet of paper I wrote all of the info on.... Please help...
1961 Apache SWB/SBW for now... Built 327 You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40. |
10-23-2009, 02:16 PM | #2 |
Member of the longbed union.
Re: Drop Member question
I'm not sure about the PB, but mine from SD was like 1200. I think they are priced the same. Which version are you talking about though? he has a couple and I know they are priced diffrent.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
10-23-2009, 02:21 PM | #3 |
I'm wanting the coil over system.. not a big fan of bags I've had them on an S10 before and was'nt happy I'm also wanting rack and pinion!!! thats the main reason for the change and to get rid of the torsion bar system.
10-23-2009, 02:29 PM | #4 |
so your talking about the version that excepts the corvette control arms. I haven't seen anyone do it on the torsion bar frames. I would PM Nate. I know he makes them for the older frames.
10-23-2009, 05:33 PM | #5 |
1961 crewcab
here are a couple threads on the 60-62 dropmember, looks to be $1425, also looks like there is a 5% discount for site supporters...
http://67-72chevytrucks.com/vboard/s...d.php?t=295367 http://67-72chevytrucks.com/vboard/s...d.php?t=295365
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-23-2009 at 05:34 PM. |
