10-24-2009, 12:58 PM | #1 |
Rear/Corner Cab Trim Removal
How do you get the corner trim (with the Bow Tie emblems) of the corners of the cab on my '85 C-10?
I thought you removed the rear corner interior panels where the seat belt bolts and there would be a bolt or nut to remove the corner trim with, but it's solid on my truck. Does it just clip to the cab? Thanks.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
10-24-2009, 01:07 PM | #2 |
3/4 Ton Rodder
Re: Rear/Corner Cab Trim Removal
It clips on. The rear trim can be slid off once you get the corner trim off.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
10-24-2009, 01:17 PM | #3 |
Thanks, is it safe to pry it off or do you need a trim removal tool?
10-24-2009, 01:20 PM | #4 |
3/4 Ton Rodder
I removed a set a while back and I pried one off and had to straighten it. I pried the other side off very carefully after I removed the rear trim and only had to straighten a dog eared corner. You may be able to use a trim removal tool though. I removed just the trim, not clips and all.
10-24-2009, 01:23 PM | #5 |
Thanks again.
10-24-2009, 01:27 PM | #6 |
3/4 Ton Rodder
Glad I could help.
10-24-2009, 02:27 PM | #7 |
If you remove the corner speaker and reach up there, there is a 10mm (I think) cap nut holding that clip to the body. Once the nut is removed the corner piece and clip slides straight out. Then the rear trim slides straight off the rear clips. Then the rear clips can be removed off the body posts.
John
Locab36 1936 low cab 1/2 ton 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 http://www.flickr.com/photos/locab36...7623329816080/ |
10-24-2009, 05:39 PM | #8 |
I removed them like you suggested and it worked perfect, and your right it is a 10mm bolt.
I'm stripping my truck right now and plan on beginning the slow process of a resto this winter, so I'm trying to keep parts that are in good shape to remain that way. I want it to look brand new again, but with a few mods, 2"/4" drop, after market gauges (Autometer Cobalt), mild 400 SB, chrome 15" Torque Thrust wheels, and some other subtle changes. Thanks again
10-24-2009, 05:57 PM | #9 |
3/4 Ton Rodder
Ok, good to know. I'll have to remember that for next time.
