10-24-2009, 02:39 PM | #1 |
How much 90wt?
I'm going to change the oil in my 3 speed and rear end of my '64 C10. How much oil goes in each? I don't want to get a 5 gallon bucket if I don't have to because I don't want to the extra oil just hanging around the garage plus I don't want to pay for all that oil if I won't use it all. Plus I don't have an oil pump for a 5 gal. pail either.
Martin Gibson
USAF Retired 1964(-ish) C10 Last edited by Martin64; 10-24-2009 at 02:40 PM. |
10-24-2009, 02:58 PM | #2 |
Re: How much 90wt?
The tranny should be around 4 quarts.... a 4speed creeper box is 5 qt.
1982 K10 SWB 1987 V20 - Sold - Doh! |
10-24-2009, 07:57 PM | #3 |
Re: How much 90wt?
It ended up being almost 2 qt for the transmission and it was some pretty old stuff that came out. It looked alot more like 100,000 mile 30 wt than 90 wt. I didn't change the rear end oil. I thought it had a drain plug, but it didn't and I didn't have a new rear gasket on-hand. The oil that's in it looks alot better than the transmission oil and it was only about 1/2 cup low so I toppped it off and I'll do it later.
Martin Gibson
USAF Retired 1964(-ish) C10 Last edited by Martin64; 10-24-2009 at 07:58 PM. |
10-24-2009, 09:48 PM | #4 |
Re: How much 90wt?
2qt? Wow. Are you sure the rear doesnt have a drain plug?
10-25-2009, 11:33 AM | #5 |
Re: How much 90wt?
Yes, no drain plug.
Martin Gibson
USAF Retired 1964(-ish) C10 |
10-25-2009, 12:15 PM | #6 |
Re: How much 90wt?
i always change to synthetics for trannies and rears
10-26-2009, 09:44 AM | #7 |
Re: How much 90wt?
Nobody has info on how much oil for the rearend?
Martin Gibson
10-26-2009, 10:08 AM | #8 |
Re: How much 90wt?
I just had my saginaw 4spd rebuilt, and it took just under 2qts.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson |
10-26-2009, 10:54 PM | #9 |
Re: How much 90wt?
It was just under 2 qts for my sons GM 12 bolt.
