Old 10-25-2009, 11:27 AM   #1
wabash15
Fuel Lines
I have a 72 burb that needs fuel and brake lines front to back. I wanted to go the prebent route and have found the brake lines but not the fuel lines. Does anyone know if they are the same as the longbed pickup? Or a supplier that has them? Thanks allot
wabash15 is offline   Reply With Quote
Old 10-25-2009, 04:26 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel Lines
I would guess the burb lines and longbed lines would be the same..but im not 100% sure, i THINK ive read someone say that though.
John
1999 Toyota Tacoma 4x4
Old 10-25-2009, 04:33 PM   #3
westofb
I really hate wet sanding!
westofb's Avatar
Re: Fuel Lines
I would think they would be different....the truck tank is behind the seat while the burb is between the frame rails behind the axle! I would think the truck lines would be several feet shy of reaching. However, the truck lines go to rubber just under the cab, I guess you could use this part and then add enough hard line to it to reach the rear mounted tank.
westofb is offline   Reply With Quote
Old 10-25-2009, 04:38 PM   #4
oldblue1968chevy
Re: Fuel Lines
ahh see, glad i didnt tell him 'GO ORDER EM, THEY'LL WORK'
thanks for clearing that up^
John
Old 10-25-2009, 06:33 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Lines
I just replaced all the fuel lines front to back on my burb a few weeks afo. If you were to get the lines for a pickup, then make the ones for the rear half, it would be very easy. The only part in my work that close to dificult was the front portion... from the back of the engine to the pump.
Old 10-28-2009, 10:59 PM   #6
ap2002
Re: Fuel Lines
where do you find the brake lines, I also need new brake lines, front to back?
thanks..
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 10-29-2009, 08:48 AM   #7
wabash15
Re: Fuel Lines
LMC - they are their individuall - not listed as a set.
Old 10-29-2009, 09:07 AM   #8
Longhorn Man
Re: Fuel Lines
prebent ones- any truck restoration vendor
straight unbent ones- any parts store
