Old 10-25-2009, 03:41 PM   #1
Mike Quillici
Windshield Replacement and Rust
At some point, I'm going to have to replace my windshield. It's cracked, to say the least. I'm concerned, though, that there is some rust around the seal, and I'm not sure how this is going to affect the installation of a replacement windshield. I'm sure several of you have dealt with this before and could let me know what I'm getting myself into. Thanks.
1972 Chevy C-10 ~ 188,000 miles give or take
Mike Quillici is offline   Reply With Quote
Old 10-25-2009, 04:03 PM   #2
mrtankone
mrtankone's Avatar
Re: Windshield Replacement and Rust
has anybody answer you cause im currious on how to put the window back on
mrtankone is offline   Reply With Quote
Old 10-25-2009, 04:14 PM   #3
70cst
70cst's Avatar
http://67-72chevytrucks.com/vboard/s....php?p=3562715
Check the above link...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 10-25-2009, 04:14 PM   #4
leddzepp
Moderator
leddzepp's Avatar
When it comes to a winshield, I let the glass guys do it...but someone will have some good suggestions for you.
Mrtankone...Hi neighbor! ( I am also in Riverside, Ca.) Welcome to the board!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-25-2009, 04:33 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
I had this problem on a '72 I had. The lip that the seal hooks up to was ate up a little bit. The glass guys were able to get it to work though. Really depends on the extent of the rust. Get a new seal, it'll help some.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-25-2009, 04:40 PM   #6
mrtankone
mrtankone's Avatar
ledzep hows the c20 comming do you have any pics posted yet
Old 10-25-2009, 05:32 PM   #7
jholley
jholley's Avatar
Safelite just put one in my 72. I watched the guy do it and decided I was glad that I paid them to do it instead of trying it myself. It looked like a real pain in the butt. Plus, it was less than $200 with the seal.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 10-25-2009, 06:06 PM   #8
cdowns
cdowns's Avatar
it really depends on if there is any solid metal to mount the winshield to// i had a casb once that i took the glass out and the whole winshield frame just came apart in chunks
Old 10-25-2009, 10:08 PM   #9
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I would think it would be common sense to have the windshield frame repaired and free of all rust before installing a new windshield. Two reasons: 1. That's the easiest time to do it and 2. It's just going to get worse until you do something about it. Just my $.02.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-25-2009, 10:16 PM   #10
70cst
70cst's Avatar
X2 It's a
Old 10-26-2009, 10:27 AM   #11
UltraBlue71
UltraBlue71's Avatar
Sandblast your corrosion and weld it back up if needed and grind it down. then prime and paint it,
At a minimum I would sand what you can and put POR-15 or some other corrosion inhibitor on it to slow it down.
If you are going to attempt a install youself-
You'll need a bottle of dishsoap and some cotton 3/8ths rope, lube the rubber seal up real good with the dishsoap, make sure the rubber is warm too, it'll fight you twice as much if its cold, put the seal on the windshield, slip the rope into the channell and position the whole thing on the truck, you pull the cord to get the lip of the seal to jump over the channel on the truck, OBTW it aint easy. Be careful smacking the glass at the corners it will crack easier than you think.
If you can get the glass and seal and instal for under 200 I would do that, the windshield and seal cost me 140!
Sometimes when guys chop these trucks they lay the windshield in on a bed of sealant like newer windshields are installed, of course you'll have to figure out a way to trim it out to hide the edge.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
