10-27-2009, 07:15 PM | #1 |
Emblems and badges restoration
Anybody remember if there are any threads about how to paint the black letters and such on our emblems? I searched but did not have time to sit for hours looking thought one of you may remember. I am trying to freshen up the Blazer emblems and the "4 wheel drive" badge form it's faded past.
10-27-2009, 07:27 PM | #2 |
SWB 4x4 Collector
Re: Emblems and badges restoration
Here is a very quick way to help you out. Clean your emblems very well with soap and water with a brush. Get you some black laquer spray paint. Then, spray the emblem unmasked. Then after the paint drys, wipe the chrome edges off with a rag soaked in laquer thinner, and for corners and hard to rich spots, get out q-tips with laquer thinner. Hope this helps, Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-27-2009, 07:30 PM | #3 |
SWB 4x4 Collector
It would be better yet, if you used a q-tip with a touch of 400 grit sandpaper around it and sand in the letter a little bit before cleaning. That way your paint has something to bite onto the chrome. Then to shine up your emblems, I use steel wool and windex lightly rubbing the surface. Really works to get tarnish off of chrome, but do that after your paint has fully dried as steel wool will leave bits of it's self until you wash it off. Trevor
10-27-2009, 11:56 PM | #4 |
I get the piece all cleaned up, then put it on a level surface. I then drop in lacquer thinner so that the entire bottom(area to be painted) is "wet". Then, take an eyedropper and fill it with "unthinned" enamel paint, drop it into the wet lacquer thinner and watch it spread out to where you want it to fill. The lacquer thinner then evaporates off and your are left with a perfect fill and no paint on the interior sides of the emblem....just the bottom where you want it.
10-28-2009, 12:03 AM | #5 |
SWB 4x4 Collector
Joel, do you use scale model paint? or like Rustoleum pint paint?
10-28-2009, 12:11 AM | #6 |
I have used both your garden variety enamels you find at the hardware store but my favorite is One Shot Bulletin Enamel. It comes in a wider variety of colors. It is the same paint that oldtime sign painters use and can be found at some automotive paint suppliers and sign material distributors. Here is their website:
http://www.1shot.com/home.html |
10-28-2009, 08:25 AM | #7 | |
I see the one shot is owned by Spraylat, they make a pretty good line of customer Powders.
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. |
10-28-2009, 08:42 AM | #8 |
I think any enamel (suitable for exterior use) would work. My only concern about model paint is its' durability in an exterior application. The exterior enamels will have UV inhibitors that will keep it from fading and I don't know if model paints have that. If you have to thin it to get it to flow, use lacquer thinner, it will evaporate off the fastest. Also, I don't know how long this has been a Spraylat product...One Shot has been around for about 50 years or more. Like anything, you will have to play around with it to get it to work perfectly. Good luck.
10-28-2009, 12:14 AM | #9 |
JJanzen,
awesome idea. It would work well for restoring the old wheel covers as well!
10-28-2009, 12:22 AM | #10 |
Ditto that - killer idea. I have always wondered what the best way to do that is. Thanks for the input.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
10-28-2009, 12:46 AM | #11 |
Tot Roddin'
Awesome idea JJanzen!
Filed that one away for future reference...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-28-2009 at 12:46 AM. |
10-28-2009, 05:20 PM | #12 |
MOVE OVER
subscribing to this post, and hoping for pics later of your progress!
No matter where you are..... There you are... Buckaroo Banzi |
10-28-2009, 05:48 PM | #13 |
Nothing to see here.....
too bad we can't give rep points jjanzen, you'd receive some from me!
post up some progress pics on the emblems, big bro.....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 10-28-2009 at 05:50 PM. |
10-28-2009, 10:24 PM | #14 |
Will be monitorin' please post pics as soon as you can. I want to use this process on my hubcaps.
10-28-2009, 11:40 PM | #15 |
I got gloss black because the area is so small...
10-29-2009, 08:23 AM | #16 |
Experiment with it on a scrap piece but I have found that a little Toluene available at all hardware stores will dull down the gloss a little. I stumbled upon it when I used a brush cleaned in it when I changed colors while painting steel patio furnature. I noticed that area that I started with was duller then the end I finished with. Then the light dawned and I realized my brush was still wet from the Toluene when I started to paint.
by itself It evaporates quickly and might just work as well as the Lacquer Thinner on enamel paints.
10-29-2009, 07:20 PM | #17 |
Restoration Virgin!
Good stuff!!...Thanks Guys!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
10-30-2009, 11:51 AM | #18 |
Great tread and those came out nice.
72 chevy 3/4 ton 4X4 |
10-30-2009, 01:09 PM | #19 |
looks like a 25cc Monojet leurlok? Beautiful work!!!!
Don is a anesthetist, so getting a syringe/needle to play with is easy. for the lay person, check with your doctor, nurse, medical supply store, or pharmacy.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
10-30-2009, 01:51 PM | #20 |
thats alot neater way of doing that than i have done, I just spray em and wipe the high spots off with laquer thinner, good idea!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
10-30-2009, 01:57 PM | #21 |
Looks good, did you put any thinner under the paint first to help it spread, or just put the laquer in?
10-30-2009, 02:40 PM | #22 |
I tried at first to put the laquer thinner in it first but the paint seemed to swarm on me so I just tried the paint out of the can and seemed to work just fine if I went slow and did not try to rush it. The paint was so viscous that as soon as I held the needle down, paint flowed out of it nice and slow. I did have to use two different syringes because after the first one was done, the paint seemed to get a little thicker and would not flow as well, but in a new syringe, paint flowed nicely. Be sure and fill the 3cc syringe up with 2cc of paint to give you a little pressure behind the paint flow in the needle.
10-30-2009, 05:38 PM | #23 |
SWB 4x4 Collector
Looks good Don, I have been thinking about Joel's way, and to me, if you use thinner to pool into the emblem, it will break down the paint quite a bit, leaving less durability, but I don't know since I haven't tried that method. Trevor
