has anyone done a rear disc brake conversion
i have an 87 2wd swb and im looking for info on doing a rear disc brake conversion. Has any one done it? if so do you have links for parts?
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: has anyone done a rear disc brake conversion
I did a swap on my 72 Super Cheyenne. I used 96 Impala SS parts and brackets from Captainfab on the 66 board. I dont know if the brackets will work with a ten bolt rear axle though. My 72 had a twelve bolt. I have also heard of people swapping in an entire rear axle from a Impala SS but I dont know the width difference. I would be interested to know if an Impala axle will work. If so, I know where I will be getting my rear discs from.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
BAD BOW-Silverado XST
You can keep the same bolt pattern by using a Caddy or Lincoln rearend. Older cars have disc brakes on the rear. Caddy rearends also correct the 1" travel path between the front and rear tires. You do have to move the perches for mounting.
Conversion kits are also available with Caddy or Vette brakes. |
94 to 96 Caprice 9C1 (Police pkg) have the same brakes as the Impala SS, and they can be found in the boneyards.
I have a 9c1 parts car I'm parting out,I can measure the rear if you guys need numbers. I'm planing on using the brakes on my 2wd K5.
06' GMC 1500 Crew cab..... |
I would like to know the wheel mounting surface to wheel mounting surface width please.
I think the Caprice stuff should work they are a 10 bolt with a 5 on 5 lug pattern would all work nicely i think
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban ![]() |
Just depends on the width. I already have my wheels and have no plans to change them or run any spacers.
does anyone have pics of there conversions
dont think there a lot of step by step instalations photos you might try the people selling those kits to look for buildlogs on there website
i seen a couple on pirate sumtin its a 4x4 website and a bit hard to navigate it seems pretty simple take out the axles remove the backingplates for the drumbrakes and install the diskbrake adapter replace the axles and mount disks on them the mount calipers and mount new brakelines and emergency brake cables if these aply to the kit . the only thing that might take some thinking is the clocking of the calipers (top front or back on the disk ) the bleedernipple of the caliper should be on the top end spacing the adapter so the caliper is somewhat centered over the disk another thing you might want to check is if youre wheels will still fit with the diskbrakes there usually bigger in diameter and stick out a bit more towarth the wheel
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
there's a ton of pics in the 1st 5 pages of my build thread... Blackbirds!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
