Old 11-01-2009, 08:14 PM   #1
72K5er
Tire size and drivability question.
How much of a difference is there for street drivability between 35's on 15" rims as compared to 35's on 17" rims. I have 35's on my K5 now with 15x8" rally rims. The suspension, ball joints, everything is pretty much new. I know it is a truck and not a sports car but it seems to be all over the road sometimes. I have tried all different tire pressures but that does not make a difference. The truck will probobally never be offroad so I don't need thel 15's for crawling or anything. Will the shorter sidewall of the 17 make a noticable difference on the street? Thanks
72K5er is offline   Reply With Quote
Old 11-01-2009, 09:32 PM   #2
shilo
shilo's Avatar
Re: Tire size and drivability question.
I doubt you would notice a difference until you start street racing it. And then the leaf springs and sway bar would make a bigger diff then wheels i think. Is your sway bar hooked up?
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 11-01-2009, 09:49 PM   #3
b454rat
The front end on my truck seems to be tight as well, but when I went from 35" boggers on 16.5x12" wheels to RADIAL 35s on 17x8.5" didn't really notice a difference. Other than noise....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-01-2009, 11:34 PM   #4
You won`t notice a difference.it sounds like you have some other problem.You either have a bump steer issue or a worn part in the bunch.
Old 11-02-2009, 11:20 AM   #5
litebulblsc
litebulblsc's Avatar
Check your toe
litebulblsc is offline   Reply With Quote
