11-02-2009, 01:04 PM | #1 |
Flush 3rd brake and back up lights in tailgate
I want to add some bright backup/loading lights and a 3rd brake light to my tailgate like this rough sketch. They will be flush mounted. Has anyone done this? Did you route the wiring out the side of the gate by the trunion or ?? Thanks.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 11-03-2009 at 06:32 PM. |
11-03-2009, 03:51 PM | #2 |
A320 Pilot/USAF Retired
Re: Flush 3rd brake and back up lights in tailgate
Deleted
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 Last edited by ChuckDriver; 11-03-2009 at 04:11 PM. |
11-03-2009, 04:10 PM | #3 |
Found this one, but it's a step side.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
11-03-2009, 05:11 PM | #4 | |
Hollister Road Co.
Can you smudge out my license plate numbers please? |
11-03-2009, 06:27 PM | #5 |
It is smudged, I did not remember where I got the photo. It was a couple of years ago when I was looking for back shots of trucks with Fleetside bumpers.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 11-03-2009 at 06:33 PM. |
11-04-2009, 08:06 PM | #6 |
orrie,
Just curious, are you planning on using jamb connectors?? http://www.streetrodstuff.com/Products/1553/
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
11-04-2009, 08:48 PM | #7 |
Hollister Road Co.
I think I would put the backup lights below the tail lights and the brake light in the cab.
11-05-2009, 01:11 AM | #8 |
You could weld these flush mount lights into your tailgate. $50 from Chev's of the 40's....(I'm still pissed at them..but that's another thread)
You've still got to figure out a way to route the wiring through the hinges in such a way that you can (somewhat) easily remove the tailgate when you need to. |
11-05-2009, 01:42 AM | #9 |
Thanks for the comments. Rhodog, I don't know if those would hold up in an exposed location like the tailgate. The truck will be used in the rain and snow. Dave I thought about below the taillights but wanted them higher so they would shoot over my utility trailer. I think surface mounted back up lights were an option below the taillights. Back window cab third brake light is too. Dan, I was thinking of a armored cable connector but had not thought about removing the tailgate, the first 20 years I drove the truck I never did, thanks for the reminder. I could also build them into the bedcover back lip.
Keep the thought coming, guys.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 11-05-2009 at 01:45 AM. |
11-05-2009, 09:34 AM | #10 |
Just a thought - minivan sliding doors typically have a 4-5 pin connector that mounts to the jamb & leading edge of the door... Mounting one or two of those in the bedside jamb, or at the roll pan would be a pretty slick way to avoid a wiring harness...
No lights if the tailgates down or removed though... |
11-05-2009, 01:42 PM | #11 | |
11-05-2009, 04:07 PM | #12 | |
Fat Fendered Fleetside
well, my thought is with the tailgate down, the lights won't do much anyways. they won't help you reverse in the dark or show the 3rd brake light much. I have thought about lights/plate etc in the gate again and again, but with the gate down (or off) they'd be useless. So if you really want them there, I wouldn't worry about the pin type connections not working when the gate is down. kind of a moot issue(how can I power lights that have no function?) Also you could look into a molex connector instead of those pin types. (some molex are weatherproof) and easy to connect/disconnect. looks up sealed molex connectors...
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
11-05-2009, 01:55 PM | #13 |
There is always the lights in the rolled ends of the bed sides. Not my cup of tea, but if you really want to do something somewhat unusual you can go with that.
